Injectors
Old May 2, 2002 | 10:05 AM
mdm's Avatar
mdm
Default Injectors
86 with cast iron heads ,edelbrock manifold ,large tube runners,everything ported,headers ,free flow exhaust,---any ideas on best injectors for this setup. how many lbs are the stock injectors. Tks :cheers: :confused:
Old May 2, 2002 | 10:56 AM
mn_vette's Avatar
mn_vette
Default Re: Injectors (mdm)
Are you planning on upgradding anything else later that might require bigger injectors? If so you're probably better off getting some bigger ones. The $30-50 more that your gonna pay will by far outway the $300 for a new set.
Old May 2, 2002 | 10:59 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I think your stock 22# injectors run at say 50-55psi will work fine. I assume you're expecting to build about 330-350hp at the crank.
My stock 22# injectors run at 47psi support 300hp at the crank and could have even gone a little lower.
Put it on a dyno with a wide band O2 sensor to be sure.
Old May 2, 2002 | 11:25 AM
NUckINg FuTS's Avatar
NUckINg FuTS
Default Re: Injectors (65Z01)
Find a set of FMS 24# injectors and you should be alright w/ that setup.
[Modified by NUckINg FuTS, 9:27 AM 5/2/2002]
To Injectors
