lets stop this motor building madness!!!!!!
thanks, george
I had a bad experience with a builder and decided I'm going crate. Problem is finding a trustworthy builder that knows what he's doing.
If you search, you will find few threads on many members that did their build up. All those members' threads were extremely helpful for my LT4 build up. I got to say that after reading and analyzing all of them at the end they were almost identical (different parts and goals). I sent lots of PMs to them and they always lend me a hand.
My LT4 was a PITA, I wanted to squeeze every horse power possible and keep it California SMOG legal and it passed.
Id like to say thank you to all of you once again!!!
I had one engine let go in my drag racing days, had an oil screen fall out of the pump, it let go going through the lights at 8000 rpm! Gawd what a mess that was.
Anyway enough about my engines. Quality parts is number one, a complete balancing of all rotating parts, and a super clean environment are necessary along with meticulous care to detail, if it ain't right don't think it'll be okay because it won't. Make it right even if the engine has to come apart again.
I won't even make any assumptions regarding your setup but from I have read in your posts about various sensors etc. being omitted and a made up harness, I am wondering if there is something there that would give you grief. I'm just asking to bring the subject up,,, I don't know.
1.some builders know how to make drag racing engines that run for 20 sec max..
2 after taking advice from several reputable engine builders found out later that advice to be bulls***
3 the more money you spend the bigger peice of S*** u get.
the best of my motors were the cheapest
4 a builder cant give you a price or warrenty because they cant build decent engines. if a builder had confidence in his ability experience and quality of parts he used why on earth wouldnt he warrenty his product..even for racing.....if a part fails its ure fault not mine get better parts...especially when the builder pics them with an open checkbook... the it hapens some times line doesnt float with me any more. buy the way that why buisness owners have liability insurance...buy it use it!!!! thell tell u if i warrentied my prouduct i would go out of buisness bingo get out!!!
5 act like a professional have an aproved tunner that u recomend and work with!!!! the its his fault and finger pointing between engine builders and tunners is absolutely (i cant even think of a word that describes my frustration)
6 if you dont know find out..
7 if you cant do it find someone that can
8 looking in the mirror i see if i treated my buisness like most engine builders treat theres i would be out of buisness 10 years ago
im looking for talking about a guy that builds engines all day every day.[/B] and when a contradiction is offered he can say thats wrong and heres why.... im in now way pointing this stuff at you personaly just your industry..and what im looking for in an engine builder...
do you know of anyone who ever went out with the intention of blowing up??? it all part or componet failure..or incompentence....
In the past I paid to have engines built.
They failed.
I taught myself & had guidance from an old time mechanic back home & became best friends.
He is gone now.
His lessons taught to me I share with everyone here on C4 nightly.
If you want to pay some one from the group on C4,
TPI 421 Jim would be my only choice.
I love building my own motors.
You can learn also..............You are ready to after 7 engines letting go.
Took me just 2 engines letting go paying others in Chi town area to decide to build my own.
Brian
Just how fast do run down the straight away(s) ?
Over 140 MPH ?
All left hand turns ?
Or a mix of sweeping left & right hand turns that are over 400 feet in length ?
With sticky racing slicks,
A C4 should be able to corner well over 1 g or even 1.3 G's.
That would be enough G force to uncover the oil pickup screen.
Long sweeping high speed turns will easily uncover the pickup screen & allow air to be sucked in then.
Even 1 million dollars $$$$ spent,
the engine would still blow up then.
No oil to the main & rod bearings for several seconds while the engine is screaming away from 5K to 8K+ RPM's.
Its an expensive upgrade>>> dry sump oil system.
Sure you know that allready.
Swinging oil pickup tubes & trap doors in oil pans for road racing are GIMICKY to me.
They don't work in roundy- round dirt track late model cars- wet sump oil systems.
At best they maybe corner .95 g's.
Can't see it working too well in a road race prepped C4 that corners over 1G easily.
Brian
They failed.
He is gone now.
Brian
Truth.
