Thermastat '85
Old Sep 23, 2011 | 12:11 PM
CSmax's Avatar
CSmax
Default Thermastat '85
Was going to flush cooling system and change thermastat at the same time as preventative mx.
What temp thermastat for an '85 L98?
Old Sep 23, 2011 | 12:36 PM
powerpigz-51's Avatar
powerpigz-51
Old Sep 23, 2011 | 01:27 PM
CSmax's Avatar
CSmax
What is the advantage or disadvantage to using a lower temp?
Old Sep 23, 2011 | 01:44 PM
navy_vette's Avatar
navy_vette
I did have a 165 (if I remember correctly) way too cold. I have a 180 now, seems to be good.
It kinda depends on what you are doing with the car and what you have done to it. Higher grade fuel, higher compression and all that fun stuff can make your car run hotter. Putting a lower thermostat in will help make sure that your coolant doesn't come even close to boiling temp.
Too cold makes your car run rich and you lose power and fuel economy.
Old Sep 23, 2011 | 02:15 PM
powerpigz-51
My theory on this is that the thermostat opening temp is picked by GM engineers to best fit (where it is actually controlling water flow) with the cooling capacity of the rest of the system to help maintain a certain (consistent) temp. 215-225 is my guess. If you put in a lower temp thermostat, it will only stay at that temp TEMPorarily on its way to it's designed temp parameter, or when it is cool enough outside to keep it lower. In other words, the temp the fans come on, radiator efficiency, (how clean it is inside and out, this is a biggie IMO) outside air temp has more to do with the temp your car will run at than when the thermostat opens. When the thermostat is all the way open, it has no more control of the temp. This is a very controversial subject on this forum, this is strictly my opinion based on my experience, with my car. I have a 185 stat w/ 2 eighth inch holes drilled, stock radiator, adjustable fan temp control (main fan comes on at 205, secondary fan at stock setting). My car on the hottest day runs from about 190-215. The secondary fan never runs. cool days (below 70) 180-195
Old Sep 23, 2011 | 04:59 PM
Muffin's Avatar
Muffin
I doubt your engine will like a 160. Mine did not. 180 works for me.
Old Sep 23, 2011 | 05:05 PM
vader86's Avatar
vader86
My opinion on the 160/180 debate is on my webpage, click my name.
But to answer your question, 195 is the stock setting.
Old Sep 23, 2011 | 05:10 PM
markKlein's Avatar
markKlein
A lower rated thermostat will mess up your vehicles heater efficiency, but make no difference at all in hot/summer temperatures, except in very rare circumstances. Everyone disagrees on this issue, but IMO best to stay with stock.
Old Sep 24, 2011 | 07:31 AM
HlhnEast's Avatar
HlhnEast
In 90* ambients, 85 car typically runs about 180-190 with a 160* stat but when air temps are cooler the car runs much lower than that. The 160* keeps temps up where my OD will work. I notice no difference in performance or mileage.
Old Sep 24, 2011 | 11:30 AM
CSmax's Avatar
CSmax
Thanks for the replys..
Gonna stick with the 195. Is there a way to tell what temp thermastat is currently installed?
Powerpigz, which fan is secondary in front of radiator or behind? Never seen the front fan come on, fan behind radiator (near engine) comes on about 222 degrees.
Old Sep 24, 2011 | 12:46 PM
ex-x-fire's Avatar
ex-x-fire
The t-stats are stamped w/ the temp rating, look at new one to make sure its correct & not boxed wrong.
Old Sep 24, 2011 | 10:05 PM
HlhnEast's Avatar
HlhnEast
You can actually test the stat by putting it in a pot of water, heating it up until it opens and read the temp with a thermometer.
Old Sep 24, 2011 | 10:35 PM
powerpigz-51
The primary is behind the radiator.....secondary in front. Secondary comes on at 238. You can change these settings in the chip if you have a chip burner as well as the "hysteresis" which is when they shut back off. I have a variable fan switch on mine, I can set the fan turn on temp to anything I want. 13 bucks at JC Whitney.
To Thermastat '85
