1996 Manifold Air Temp sensor
Old Sep 23, 2011 | 01:20 PM
LD85's Avatar
LD85
Default 1996 Manifold Air Temp sensor
Question, does this Manifold Air Temp sensor screw in or does it look like the sensor in the pic?
My new FAST harness plug does not fit the 1985 sensor, which is basically a coolant type sensor, so I had to buy the newer more sensitive sensor.
Where is this mounted in the 1996 Corvette?
Old Sep 23, 2011 | 01:22 PM
dizwiz24's Avatar
dizwiz24
on my 93 (when i still had the stock intake) it plugged into the rubber intake hosing in between the air filter and throttle body.
Old Sep 23, 2011 | 04:55 PM
RichS's Avatar
RichS
96 is in the intake belows right before the throttle body.
To 1996 Manifold Air Temp sensor
