Gas Pedal Replacement
Old Sep 25, 2011 | 09:19 PM
grantar2's Avatar
grantar2
Default Gas Pedal Replacement
Guys broke my gas pedal. Saw a couple of old posts but no photo's or info on how to replace it. Also saw a listing for RD Racing and CorvettMike making more durable replacements but all links were broken and e-mails no good.
Any help appreciated.
Old Sep 26, 2011 | 12:03 AM
Black84's Avatar
Black84
These are hard to get to to replace the cable once you install the new pedal assembly but it can be done. If you are double jointed and have small hands it will be easier.
Here is one source: http://www.corvettepartscatalog.com/...roducts_id=615
Old Sep 26, 2011 | 12:43 AM
Sidney004's Avatar
Sidney004
I didn't see what year yours was, but the LT1 uses a different pedal than the one shown above. I would recommend using a factory pedal not an aftermarket. If the dimensions are off just a hair it won't swivel properly and the bushing diameter is critical. If you can't find a new factory one, I would get a used one.
As for installing it; with the seat all the way back, I was lying on my back and its partly by feel once you see whats going on with the cable. If you are 6'5" with big hands, you will need to get someone smaller to do it. Its a bit of a PITA but very doable.
Old Sep 26, 2011 | 09:40 AM
grantar2's Avatar
grantar2
1990 L98. I am 52, 6'3 and 265. I will end up having to pay someone
Old Sep 26, 2011 | 11:20 AM
navy_vette's Avatar
navy_vette
That's why you have kids, right?
Old Sep 26, 2011 | 04:31 PM
Deepa's Avatar
Deepa
swapping out the accel cable is an absolute nightmare.
Old Sep 26, 2011 | 05:03 PM
ScaryFast's Avatar
ScaryFast
I'm 6'4" and have done it lots of times
Gas pedal replacement is a snap on these cars. two 10 mm bolts that hold it to the firewall and a little plastic clip that holds the throttle cable to the pedal arm.
With a long-*** extension you can remove the two nuts while sitting in the seat. The clip, too, but it's by feel since you can't see it.
Grab the bottom of the pedal with one hand, the top with the other. Feel the clip at the top. Squeeze the back of it and push it forward (or rotate the pedal from the bottom, pushing the top toward the firewall).
Seriously, 10 minutes.
You can get a used pedal from one of the guys parting out a car for about $30 shipped. At least that's what I paid a few months ago...
I've used an LT1 pedal in a L98 car and vice versa. Just check that your TPS goes from 0% to 100% and you'll know it's working properly. Actually it's more like 5% to 95%, but you get the idea.
Old Sep 27, 2011 | 02:35 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Just pull the seat.
Remove the seat cushion and four bolts. DONE!
To Gas Pedal Replacement
