Locking lug nuts-no socket!
Old Sep 26, 2011 | 04:32 PM
fcable's Avatar
fcable
Default Locking lug nuts-no socket!
I recently purchased a used C4--a project car in need of a lot of TLC. One of the wheels has a factory style locking lug nut (not necessarily the one that came with the vehicle). And, as you would guess--no socket for it! Also, my guess is that one of the rear wheels had one too, and they had to get the wheel off for some reason. So they just took the old cutting torch and cut it off in the wheel! (Ouch!). Anybody got any suggestions as to how to get this other one off in a "Corvette friendly way"? Thanks.
Old Sep 26, 2011 | 05:36 PM
robtx's Avatar
robtx
look on youtube about removing key lug nuts
Old Sep 26, 2011 | 06:34 PM
c4cruiser's Avatar
c4cruiser
Most tire shops have ways to remove locking lug nuts if no key is available. Usually involves a BFH and strong arms.
If you decide to keep using locking lugs and will buy another set, get a spare key and keep it at home.
Old Sep 26, 2011 | 07:40 PM
leesvet's Avatar
leesvet
Find the approx size impact socket thats 12 pt. and pound it on with a BFH and remove as usual.
In the future, get some Gorilla Locks. They are coded and have a code number assigned to each set. That is on a sticker that you keep in the glove box or console lid. If you ever loose your key, call Gorilla with that number and they will send you a new key.
Old Sep 26, 2011 | 07:49 PM
c4speed's Avatar
c4speed
From: Atco Raceway in between Pa & Nj 13.073 @ 106 MPH
One of mine was messed up,got it off and done away with the other three.It is not a DD and I keep it in a garage.
Old Sep 27, 2011 | 01:54 AM
oldalaskaman's Avatar
oldalaskaman
I sometimes use a small cold chisel and gently cut into the edge of the lock counter clockwise, takes a nice hefty hammer but they usually start moving after a few taps. they're usually only installed hand tite.hope this helps
Old Sep 27, 2011 | 12:06 PM
skybolt31's Avatar
skybolt31
I removed mine as well. I understand some people have to leave there car where it is at risk and the locks area good idea, but consider this, how many people with wheel locks keep the key somewhere outside of the car? When I had the locks, I left the key in the console. Unless the thief is new on the job, when he spots the locks, he will then break the window and get the key out of the console.
So I figure used sawblades aren't that hot an item anyway and I go without the locks.
Old Sep 27, 2011 | 12:29 PM
montecarlo4's Avatar
montecarlo4
i was able to tighten the other 4 just a smidge more than use vice grips on the locking nut to get it off, worked rather easily.
good luck
matt
Old Oct 3, 2011 | 10:27 PM
fcable's Avatar
fcable
Default Locking lug nuts, no socket
I appreciate all the responses. I found a tool--Performance Tool #M980, Lug Nut Removal Tool. Cost about $11 + shipping from BarMac. I worked great using an impact tool, and you don't have beat on the wheel spindle with a big hammer. Thanks again to all who assisted.
To Locking lug nuts-no socket!
