"bat"
Old Sep 27, 2011 | 01:22 PM
Timo's Avatar
Timo
Default "bat"
Where is the "BAT"?
Old Sep 27, 2011 | 01:41 PM
1963SS's Avatar
1963SS
A long piece of wood that smacks a baseball usually located in a ballpark or the Battery. If a battery it usually refers to the Pos (+) terminal.
Old Sep 27, 2011 | 01:44 PM
Zogs2011's Avatar
Zogs2011
the bat is the only mammal naturally capable of true and sustained flight so could be anywhere.
Old Sep 27, 2011 | 01:50 PM
Timo's Avatar
Timo
Originally Posted by Timo
Where is the "BAT"?
Service Manual says: If i get a compression test, i must disconnect the "BAT" ?
Old Sep 27, 2011 | 02:10 PM
TWISTERUP's Avatar
TWISTERUP
The manual is refering to the battery (BAT) positive (+) cable connection --as "1963SS" stated
Since the starter is used when checking compression I'm unsure why the manual would want the battery disconnected ??---remove the coil wire and have at it.
Old Sep 27, 2011 | 02:23 PM
Timo's Avatar
Timo
Yes, the manual want you disconnect the distributor connector (4 wire), but how you rotate the motor if your battery is disconnected ?
Old Sep 27, 2011 | 02:28 PM
Steve85's Avatar
Steve85
Cruise-In V Veteran
Pink wire at coil? White wire is Tach I believe the pink is labeled BAT and is the 12v source for the coil.
Old Sep 27, 2011 | 03:53 PM
navy_vette's Avatar
navy_vette
You use a BAW
Big *** wrench.
There is a bolt on your crank shaft balance. Remember, the chevy motor rotates counter clockwise in relation to you WHEN YOU ARE IN THE CAR.
Old Sep 27, 2011 | 04:34 PM
1963SS's Avatar
1963SS
Really, to do a compression test just pull the coil wire and crank the engine.
1) Remove coil wire
2) Remove plugs
3) Open throttle
4) Screw compression tester into spark plug hole
5) Turn engine over using the key
6) Record cylinder number and pressure reading
7) Repeat seven more times in different spark plug holes
You're looking for all cylinders to be about equal with not much more than 10% difference between all readings.
And then there's the "Wet Test".
To "bat"
