Time for new injectors.
Old May 2, 2002 | 10:32 PM
ZAD54's Avatar
ZAD54
Default Time for new injectors.
My injectors in my '88 coupe are clogged as many of you problem know all too much about. I've tried unsuccessfully at having them cleaned to no avail. So I've decided to install a new set. My question is: Should I go with a set of stock injectors or a set with a high poundage. My car is modified only with minor bolt ons so far but hope to add my soon, and maybe even a little "giggle gas". Any advice will be appreciated. :cheers:
Old May 2, 2002 | 11:17 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Time for new injectors. (ZAD54)
You are better to stay with stock 22# injectors with slight mods.
Have you tried Rich at Cruzin Performance. His service reconditions, sonic cleans and flow test em for $10/injector. In shop time is 48hrs.
I just received my 9 injectors back today and the 8 are now in the fuel rail waiting for the rain to stop.
Old May 2, 2002 | 11:42 PM
daves87's Avatar
daves87
I just got mine back today also. They look great and the turnaround time is super fast. $97 including the cold start injector. Cant beat it. :cheers:
Old May 3, 2002 | 12:09 AM
vader86's Avatar
vader86
Default Re: Time for new injectors. (daves87)
If you dont get the current ones serviced, go with FMS 24's. Your computer will adjust the fuel flow, so you wont have to worry about it running rich.
Old May 3, 2002 | 10:23 AM
Goody's Avatar
Goody
Default Re: Time for new injectors. (vader86)
Most on this board change to some version of the Ford injectors. Either #24 or #30 will work. Do a search and read up on this stuff. I'm considering the same swap myself. $225 a set for new sure beats the GM price and those rip off artists in Ecklers or MAD. :seeya
Old May 3, 2002 | 02:09 PM
gbr's Avatar
gbr
Default Re: Time for new injectors. (Goody)
I've replaced the stock injectors on my 89 L98 with the FMS24# that I ordered off of summitracing.com for $219 w/free shipping...unfortunately my car is not running now so I can't tell you how they are working...but others I have talked to have claimed performance and idle improvement.
Old May 3, 2002 | 05:06 PM
Mike263's Avatar
Mike263
Default Re: Time for new injectors. (gbr)
I just installed the FMS24# from Summit. No problems with injectors - car runs great. Had a problem right after the install, but it turned out to be the MAF sensor, not the injectors.
[Modified by Mike263, 3:09 PM 5/3/2002]
Old May 3, 2002 | 06:42 PM
ZAD54's Avatar
ZAD54
Default Re: Time for new injectors. (65Z01)
Does Cruz Performance have a website? If so can you send me the link. I might go that route if I don't change to bigger injectors. Thanks
To Time for new injectors.
