Calling -= Jeff=-
Old May 2, 2002 | 10:42 PM
~~Tin Man~~'s Avatar
~~Tin Man~~
Default Calling -= Jeff=-
Hey Jeff. I have had some problems with my a/c controller ( 89 coupe) Thanks to Paul in Cal. I have fixed my circuit board (bad resistors and bad solder connections) Paul in Cal. was a great help working it out seems to have helped as far as control, everything seems to be ok buttt, I have no heat I believe the problem lies at the actuator, the plastic arm seems to be solid but no movement. Do I need to remove dash to access the actuator ?
I here you have been threw this one. Any suggestion would be a great help.
THANKS -=Jeff=-
[Modified by ~~Tin Man~~, 4:56 AM 5/4/2002]
Old May 2, 2002 | 11:35 PM
6spd89's Avatar
6spd89
Cruise-In II Veteran
Default Re: Calling -= Jeff=- (~~Tin Man~~)
Here is the number-----
1-800-728-8267 Superior chevy
Matt
Old May 3, 2002 | 01:46 AM
pablocruise's Avatar
pablocruise
Default Re: Calling -= Jeff=- (6spd.89)
Matt
ooops! Not Jeff Kopp, -=JEFF=- the guy that took his 89 completely apart and put it back together again. :cheers:
Jeez TINMAN, the way it came out, makes it sound like I caused the probs on your controller. :lol: :lol: I hope the forum won't think I'm a goober :lol: :lol:
[Modified by 89 Paul in Cal, 9:49 PM 5/2/2002]
[Modified by 89 Paul in Cal, 9:50 PM 5/2/2002]
Old May 3, 2002 | 09:51 AM
-=Jeff=-'s Avatar
-=Jeff=-
Hey Jeff. I have had some problems with my a/c controller ( 89 coupe) Thanks to Paul in Cal. I have fixed my circuit board (bad resistors and bad solder connections) seems to have helped as far as control, everything seems to be ok buttt, I have no heat I believe the problem lies at the actuator, the plastic arm seems to be solid but no movement. Do I need to remove dash to access the actuator ?
THANKS -=Jeff=-
Which actuator? the Temperature door one? if it the Temp Door motor, you can do it with removing the dash.. just drop the Hush panel on the driverside and you should be able to see it. black box with a rod going towards the firewall.
You may want to get the Service Manual and run through the test procedure. I had the same problem and fixed the Programmer Resisters and the programmer still ended up being bad.
Old May 4, 2002 | 12:34 AM
6spd89's Avatar
6spd89
Default Re: Calling -= Jeff=- (89 Paul in Cal)
OOOOOOOppppppppsss,My BAD!!!!!
Matt
Old May 4, 2002 | 01:11 AM
~~Tin Man~~
Default Re: Calling -= Jeff=- (-=Jeff=-)
Hey man. thanks for the info. I 'll get back in the ring and give it a go.
you are the man.
Old May 4, 2002 | 07:43 PM
-=Jeff=-'s Avatar
-=Jeff=-
Meant to say without removing the dash.. not with.. I gotta learn to proof read my posts
To Calling -= Jeff=-
