External or Internal Balance ( LT-1 ) ????
Old Sep 30, 2011 | 02:29 PM
Blue95C4's Avatar
Blue95C4
Default External or Internal Balance ( LT-1 ) ????
A respected local mechanic said that the 1995 LT-1 was an internally balanced engine and he said that a "neutral balanced" flywheel would be needed when I replace the Clutch assembly on my ZF tranny.
I thought all one piece rear seal engines were externally balanced by the flywheel, but he says the front harmonic damper does that job.
I'd hate to get the wrong flywheel ... What's the real scoop ?
Old Sep 30, 2011 | 02:39 PM
1963SS's Avatar
1963SS
The harmonic balancer is neutral balanced and the flywheel is externally balanced. I do believe that the old LT1 engines back in the 70's were neutral balanced flywheels. Maybe that's what he's thinking of. This is just a guess though because I run a slush box. I KNOW they are externally balanced. Call a respected clutch supplier and make sure or wait for one of our own CF gear wringers to step in.
Old Sep 30, 2011 | 03:12 PM
TWISTERUP's Avatar
TWISTERUP
From every thing I've been told over many years--all SBC with stock cranks are internal balanced. The exception is the 400 which is balanced externally.
Old Sep 30, 2011 | 03:15 PM
Strick's Avatar
Strick
The 92 LT1 is definetly external balanced. I have a package from Mr. Kilibrew showing how they balanced the LT1. I believe the rest of the LT1's are also externally balanced. Just look at the outer edge of the fly wheel and if it has holes in it with some of them filled, it is externally balanced.
Old Sep 30, 2011 | 03:28 PM
96GS#007's Avatar
96GS#007
A picture is worth a thousand words. Circled in red is the offset weight that is cast into a dual mass flywheel for an L98/LT1/LT4. An auto with a flex plate is externally balanced as well
The single mass flywheel on the right has the weight bolted in place (it's the hard to see black rectangle with three bolts on the right side of the flywheel) in order to match the dual mass. This is what you need. If you build an engine and you need a neutral flywheel, you unbolt the weight.
Old Sep 30, 2011 | 03:46 PM
TWISTERUP's Avatar
TWISTERUP
This is really gonna start a weeing contest-but so be it The holes drilled and/or weights added to balancers/dampners/flywheels and flex plates are simply to balance that particular component making it "neutral balanced". If that were not true you wouldn't be able to replace a balancer/fly wheel or flexplate with out removing the crankshaft and rebalancing as a assembly. Once again this is true of STOCK cranked engines only. Some of the "stroker" cranks I've dealt with are external balanced-but that was years ago i can't speak for modern day stroker kits. But once again unless it's a 400SBC it's balanced internally.
Old Sep 30, 2011 | 04:25 PM
96GS#007's Avatar
96GS#007
See the giant weight on the SPEC flywheel in my pic? That's to match balance it to the dual mass flywheel that has the cast in weight. These engines are externally balanced in the rear.
The holes in the LT dampers and flywheels are to fine tune the balance. There were some vibration issues that resulted from production problems. There is a service bulletin that discusses the balancing procedure used at the factory as a result. These weights did not neutral balance these components.
If you buy a new LT1/4 damper, the installation directions are very clear...Add pin weights in the same location(s) as the damper being replaced. This is not to neutral balance the damper, it is to match it to the existing one. The new ones are already neutral.
My stroker crank is internally balanced. My ATI damper is neutral, as is my SPEC flywheel and pressure plate.
So, to answer the OP question: Your stock LT1 is absolutely externally balanced in the rear. If you replace the dual mass, it will bolt on just fine since the weight is cast in place. If you install a single mass flywheel like the SPEC unit pictured above, be sure to bolt the weight in place before installing the flywheel.
These are the facts.
Old Sep 30, 2011 | 04:46 PM
TWISTERUP's Avatar
TWISTERUP
I stand corrected--just did some research and the LT1 was one of the engines given as a example of a engine which is internally balanced in the front BUT externally balanced in the rear. I'm never to old to learn. I guess as far as my weeing contest goes--it sorta blew back in my face
Old Sep 30, 2011 | 05:00 PM
1963SS's Avatar
1963SS
That's why I said externally balanced as well. Any internally balanced crank comes with instructions to remove the weights on the stock flexplate. (If you intend to use stock). Yep, you're externally balanced.
Make sure you tell your builder. He's never too old to learn either.
Old Sep 30, 2011 | 09:52 PM
96GS#007's Avatar
96GS#007
Old Oct 1, 2011 | 07:03 AM
rodj's Avatar
rodj
Technically you are right
The counterweights on the crank balance the reciprocating mass even though
one of the counterweights on the 2 pce RMS internal balance crankshaft
is external to the engine itself.
Because of the reason I mentioned above ,on the 1 pce RMS engines,
that counterweight could not be cast on the crank flange so the weight
was moved to the flywheel.
The internal balance arrangement has not changed ;only the position of the weight moved.
The aftermarket just confuses everyone by calling them Int or Ext balance to
differentiate between the two crank styles , not a different balance arrangement
The 400 SBC crank didn't have enough room inside the block for the extra mass
of the longer stroke so GM made it externally balanced.
They did this by adding a counterweight to the vibration dampener and to the flywheel;
hence true external balance
Old Oct 1, 2011 | 07:41 AM
TWISTERUP's Avatar
TWISTERUP
I'm aware that "Technically" I was correct. However after doing some reading and research online I see how my opinion was---hmmm slightly flawed I based my idea on the fact that back in the day when I built a 383-- I had one choice--using a stock 400 crank I HAD to use the balancer and flex plate from the donor crank. Not true any more with the aftermarket cranks. Lots of info online nowadays--but you have to weed through it, so to speak to arrive at what is true.
Old Oct 3, 2011 | 12:15 PM
mtwoolford's Avatar
mtwoolford
Run Forrest !! Run !!!
To External or Internal Balance ( LT-1 ) ????
