Code 32 question for a 90 with a L-98
Old Oct 1, 2011 | 12:59 AM
mrvoodoo's Avatar
mrvoodoo
Cruising
Default Code 32 question for a 90 with a L-98
I changed the EGR, reset the computer, and the car runs better, BUT after 12 miles at 2000 RPMS, it happens again the light comes on and that nasty code 32 reappeared...... Did I forget to do something ??
Old Oct 1, 2011 | 02:55 AM
rodj's Avatar
rodj
Originally Posted by mrvoodoo
I changed the EGR, code 32 reappeared......
Maybe you have a broken wire or faulty EGR temp sensor.
If the ECM does not see the sensor close when it is supposed to ;it will give the same code as a faulty EGR valve.
Code 32 indicates a malfunctioning EGR valve, a malfunctioning EGR temperature diagnostic switch, or an open or short to ground in circuit #935 or #999 (depending on year and model).
Old Oct 1, 2011 | 03:14 AM
mrvoodoo's Avatar
mrvoodoo
Cruising
Thanks, I'll check it out......
Old Oct 1, 2011 | 06:57 AM
Flame Red's Avatar
Flame Red
Another thing to check is those very small ridges "hoses". Mine seperated and caused a vacuum leak. Was not easy to spot.
But I eventually just disabled Code 32 in the ECM since I had an Ostrich.
Old Oct 1, 2011 | 08:23 AM
Churchkey's Avatar
Churchkey
My 90 is also code 32 sensitive. When I have time will tune it out as Flame Red suggested.
In the mean time when the SES lights up while driving I put the trans in neutral, shut the engine off & coast for 4-5 seconds. Restart & its good to go, maybe for the rest of the day.
Just a reminder if you attempt the rolling restart, just kill the ignition do not lock the steering wheel :~)
Old Oct 1, 2011 | 09:28 AM
RLG's Avatar
RLG
some of the vac. lines are plastic and become brittle then they break.
Old Oct 1, 2011 | 02:51 PM
mrvoodoo's Avatar
mrvoodoo
Cruising
Thx,Looks like I have my work cut out for me...........
To Code 32 question for a 90 with a L-98
