Shift point Changes....HOW?
Old May 3, 2002 | 01:06 PM
mn_vette's Avatar
mn_vette
Default Shift point Changes....HOW?
I just got my Ed Wright custom chip back and the revlimiter is set somewhere over 6100(i've been to chicken to find out how much more) I would like to up my shift points to 5800-6000 at WOT.
I've been told that with my '93 tranny there is a cable comming off of the ASR module that needs to be adjusted, there are 4 cables, 1 doesn't have an adjustment, one goes to the throttle boddy, one goes to some mechanical thing over the battery, and the last one goes across the top of the engine by the firewall to something unknown.
Which cable do I need to adjust? and do I need to make it shorter or longer?
Thanks for the help guys and gals
Old May 3, 2002 | 01:28 PM
Vic'89's Avatar
Vic'89
Default Re: Shift point Changes....HOW? (mn_vette)
You can mess with the TV cable, but the proper way is to change the weights inside the governor.
Vic
Old May 3, 2002 | 06:19 PM
93 ragtop's Avatar
93 ragtop
Default Re: Shift point Changes....HOW? (Vic'89)
Vic is correct!! the tv cable is the one going down to the transmission, and it has more of a effect over the shift firmness, and part throttle shifts. It basicially controls pressure. The way to change the wot shift points is to work on the govenor. You can get a kit from B&M for this.
Old May 4, 2002 | 09:38 AM
mn_vette's Avatar
mn_vette
Default Re: Shift point Changes....HOW? (Red 86 4+3)
I tried changing the TV cable, one problem, its already maxed out. I can make them sooner but not later.
so how do you "work on the govenor". I'm wondering what the theory behind how the govenor works.
Old May 4, 2002 | 11:09 AM
93 ragtop's Avatar
93 ragtop
Well I'll give you my opinion on how it works. It spins somewhat like a gyroscope. it has weights that move with increase of rpm, and the springs hold them back. By changing the weights, and or springs, you can alter the shift points.
To Shift point Changes....HOW?
