fuses
Old Oct 7, 2011 | 05:19 PM
saltbob@sbcglobal's Avatar
saltbob@sbcglobal
7th Gear
Default fuses
I have a 1984 and replaced starter it shorted out but its ok
my ? is no power any where checked fuses and breakers on side of
body by windshiled does any one know where any other fuses might be
car wont crank no lights Thanks saltbob
Old Oct 7, 2011 | 05:56 PM
RLG's Avatar
RLG
Fusable link.
Old Oct 8, 2011 | 06:19 PM
TJM's Avatar
TJM
Fusible links are behind the battery. There should be a power distribution block with a flock of red wires.
Fuse links are essentially pieces of wire designed to melt.....slowly, unlike fuses. They power motors which tend to suck a lot of current.
They can be bought for small $$$ at almost any auto supply.
Old Oct 9, 2011 | 08:55 AM
HlhnEast's Avatar
HlhnEast
Yup, the fusible link saved you a big conflagration.
Old Oct 10, 2011 | 11:32 PM
saltbob@sbcglobal
7th Gear
Default to all that posted help
thanks all that replied i finally wired around key switch and put in a
push button switch to my suprise it also brought back my rear window
release and power windows thank goodness all i need to do now is
put in a kill switch just got the car and i think a teenager messed with
the wiring nothing ele. behind battery the car was modifed for drag
racing
To fuses
