Main engine connector
Old Oct 9, 2011 | 10:57 PM
illenema's Avatar
illenema
Default Main engine connector
Is there a special way to disconnect the main engine connectors under the PCM to remove engine?
Update: tricky little sucker considering you cant see one of the lock latches.
Old Oct 9, 2011 | 11:16 PM
TRACKMAN2's Avatar
TRACKMAN2
i just pull all the wires and lay them up on the fire wall..you want to take the wires with it?
Old Oct 9, 2011 | 11:18 PM
illenema's Avatar
illenema
I need to remove both connectors intact if possible
yes Im swapping engines, is there a lock?
To Main engine connector
