Dynamic EFI
Old Oct 12, 2011 | 09:35 AM
steven mack's Avatar
steven mack
Default Dynamic EFI
Anybody using A Dynamic EFI computor system?
Old Oct 12, 2011 | 10:03 AM
mseven's Avatar
mseven
I've worked with the EBL stuff...it works fine although many tables are tittled differently than using other Tuner pro or C.A.T.S type hacks. All software (tuner pro) and definitions are propriatary to the ebl, so any other hacks/def. bins etc. or any other SD files cannot be used.
If you are tyring to improve the 85 ecm, I would re-pin and use the 165 ecm. For other applications that require SD (blowers etc.) or just wanting to convert to SD, I would re-pin/and or re-wire for the 727/730 ecm.
my .02
Old Oct 12, 2011 | 10:05 AM
qws's Avatar
qws
Yes I am. And Mseven's my tuner. He loves it!
Old Oct 12, 2011 | 04:58 PM
steven mack
Default Dynamic efi
Yeah Mick Knows his stuff.I have the 165 computer.I was thinking this would be a better route to go than buying all the Moates stuff for tuning. Dynamic EFI sells the updated speed density computer and Daughter board for $455.Is this system easier to tune and does it accommodate a wide band 02 sensor.
nutz4c4's Avatar
nutz4c4
Are ya sure about that?.....
Old Oct 12, 2011 | 05:53 PM
Rohn's Avatar
Rohn
I am sold on dynamic.
Flash based system with ign on engine off.
Very fast system (baud). Shows data from sensors changing like every tenth of second.
holds 7 diff .bins
Expanded tables for VE AE PE SA.
Comes with 10 diff V8 .bins for assort of applications.
Is own dash board that is easy to read.
Creates a corrected .bin as you drive to flash at your convenience.
supports N20 + boost.
allows WB read out in log or learn from WB
fantastic support. and support from other forum members at 3rd gen.
go to site and check it all out.
Old Oct 12, 2011 | 10:40 PM
steven mack
Thanks Rohn for the added info .There site doesn't mention some of the things you have listed .Looks like I will order one of their computers.
Old Oct 13, 2011 | 10:36 AM
Rohn's Avatar
Rohn
On thirdgen.org there is a very long thread started by RBob outling the EBL on day one of its creation. Q and A. May want to check it out. All your questions have already been asked. Also may want to search there for EBL. Every possible Q has been asked. I bet I have a 100-500 treads started on EBL. Also you will note he answers in 24 hour or typically in an hour. i am still waiting for a response form Holley on my N20 Q. It has been 2 weeks now!
One his site are links to Intro to tuning with EBL part 1 + 2. All is explained in detail. Part 1 is TunerPro and datalogging part 2 is tuning tips and explanation of the constants, flags, tables in tunerpro and his EBL specific XDF as mentioned above.
Old Oct 15, 2011 | 09:07 AM
steven mack
Default Dynamic EFI EBl
Rohn what size engine are you running in your Vette?
Old Oct 15, 2011 | 10:44 PM
Cliff Harris's Avatar
Cliff Harris
RBob is probably the most knowledgeable tuner out there on the older ECMs. He has a very broad and detailed knowledge of the code and the electronics. He wrote a lot of the tuning stickies on ThirdGen.org.
Old Oct 16, 2011 | 02:45 PM
steven mack
Thanks Cliff I have read many of his posts Third Gen is my second home for advise next to this forum.I just read one of his posts that states that the system will not support the air injection system on TPI's.
Old Oct 16, 2011 | 04:13 PM
ToniH's Avatar
ToniH
If you mean the air pump (A.I.R.) then the EBL P4 does support it.
Old Oct 17, 2011 | 11:28 AM
Rohn's Avatar
Rohn
350 cid Edel rpm 64 cc heads, comp cam 224/230 @ 114, holley projection manifold with 7.4L TBI, 80 lbs injectors at 23 lbs, hedman headers with real duals crossover, hooker aero muffs. Innovate WB with pillar gauge, N20 kit by NOS with 75-100HP, EBLECU
To Dynamic EFI
