84 has trouble starting
Old Oct 12, 2011 | 08:02 PM
torchredcorvette84's Avatar
torchredcorvette84
3rd Gear
Default 84 has trouble starting
My 1984 corvette has trouble starting, I've narrowed it down to the drivers side door plunger. I have to leave the door wide open and play with the plunger while I hold the key forward. sometimes it starts right away and sometimes it takes a half hour. I was wondering if anyone could walk me through how to fix it. Thanks.
Old Oct 12, 2011 | 09:46 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Stop playing with the door (which has NOTHING to do with the starting issue) and start diagnosing the actual issue.
And if you want help, start by telling us what is NOT happening. For example, does the starter crank? Or not?
Old Oct 14, 2011 | 05:01 PM
torchredcorvette84
3rd Gear
Well the starter cranks and the car starts just fine, but only if i move the plunger to that one perfect spot. so it IS the door. I took the plunger off and there are three little wires, I have no idea how this would have anything to do with starting the car but it obviously does.
Old Oct 14, 2011 | 07:56 PM
383vett's Avatar
383vett
What's a door plunger? Mine are missing.
Old Oct 15, 2011 | 12:09 PM
torchredcorvette84
3rd Gear
The little thing that pushes in and out to tell if the door is open or closed.
Old Oct 15, 2011 | 01:28 PM
3D87C4's Avatar
3D87C4
In my '87 FSM the theft deterrent system schematic shows a starter interupt control terminal on the Theft Deterrent Controller (page 8a-133-0), but it is marked not used. Is it possible this is used in the '84? Maybe someone could take a look in an '84 FSM & report?
torchredcorvette84:
Do you have a FSM?
Which plunger are you fiddling with? There are two per door on my '87---one on the door jam and one on the door itself. Neither are directly involved in the starter circuit, but you'll want to be sure if/when you try to buy a replacement.
Old Oct 17, 2011 | 10:56 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
The car should start, door open or closed. SHOULD. So assuming someone hasn't done some creative engineering...thing shouldn't care what is going on with the door. Why don't you pull the door apart and see what is going on in there, wiring wise?
To 84 has trouble starting
