87 L98 sensor locations
Old Oct 14, 2011 | 10:30 PM
daveshea's Avatar
daveshea
Default 87 L98 sensor locations
I am in the process of repairing a blown head gasket on an 87 L98 engine. While I have everything apart, I am going through and cleaning and replacing various items.
I would like to replace ALL of the relatively inexpensive senders and sensors that are more accessible now that everything is apart.
I have searched and tried to find a set of photos showing every sensor in the engine bay that would attach to or hang off of the engine, but am coming up short.
Does anyone know of such a post, or a set of photos with the various sendors and sensors circled for easy ID.
Yes, I do have an 87 service manual as well, but really am looking for more than a drawing that just shows approximate locations.
Thanks for the help!
-David
Old Oct 14, 2011 | 11:27 PM
vetteoz's Avatar
vetteoz
TPS circled
Cold start switch next to it
IAC circled
TPS above it
Oil pressure sender (1 wire ) and fuel pump switch
In this location (90 shown below has different type units)
Temp gauge sender (pass side )
If you have the Aux fan option , switch for the fan is in same location on drv side head ( between #1 and 3 cyl )
Oil temp sensor
Old Oct 14, 2011 | 11:33 PM
vetteoz's Avatar
vetteoz
Also replace
one way valve for vac system
and check wiring to tacho filter.Commonly get brittle and break
Old Oct 15, 2011 | 12:16 AM
leesvet's Avatar
leesvet
I have relocated many of my sensors and signal devices just for convenience. I tend to add wire and move things toward the battery to mount somehow. The oil sendernow lives just over the booster.MY EGR solenoid is on the back bolt in the bracket on the air pump...Temp sensors are extended out so that they can be seen and serviced. Did that thru brass tube extensions.
Many more to go.
Old Oct 15, 2011 | 09:24 AM
daveshea's Avatar
daveshea
Thank you! Those pictures are extremely helpful!
Old Oct 15, 2011 | 09:19 PM
daveshea's Avatar
daveshea
Need help on the oil pressure switch...
The picture appears to be of the one wire switch AND a two-wire switch, both connected with a metal device connected to the rear top of the engine block.
Do I buy BOTH the one wire and two wire switches separately, and then unscrew the old ones from that metal fitting, and reinstall with the new ones?
I haven't gotten to actually look at the old one yet...
Old Oct 16, 2011 | 01:13 AM
Cliff Harris's Avatar
Cliff Harris
The oil pressure sender with one wire goes to the instrument panel to show oil pressure.
The oil pressure switch with two wires is the backup for the fuel pump relay. It is connected in parallel with the fuel pump relay so you'll have fuel pressure if the relay doesn't work for some reason.
Old Jul 29, 2019 | 01:54 PM
d4d4u1's Avatar
d4d4u1
Please replace pictures, they are no longer available for viewing.
Old Jul 29, 2019 | 02:12 PM
c4cruiser's Avatar
c4cruiser
You mean the pics from 8 years ago??
Old Jul 29, 2019 | 02:39 PM
d4d4u1's Avatar
d4d4u1
I know they are 8 years old, but the info they reference is still relevant. these must have been links or some other for of picture upload.
Old Jul 29, 2019 | 02:50 PM
Hot Rod Roy's Avatar
Hot Rod Roy
I think you need a computer with a 286 microprocessor to see those pictures.
Old Jul 29, 2019 | 02:55 PM
d4d4u1's Avatar
d4d4u1
HAHAHA... Very Funny...
Kinda like an ID10T error....
or the issue is between the keyboard and the seat...
Or my favorite.. It works on FM, (F'en Magic)
No, I have found that images stored on external servers like "image bank" , "Getty" and such often loss images and never recover them.
Old Jul 29, 2019 | 07:08 PM
aklim's Avatar
aklim
Overkill. 8088 would work
Old Jul 29, 2019 | 09:11 PM
CorvetteRules's Avatar
CorvetteRules
Last post made by member was in 2014
Old Jul 29, 2019 | 10:53 PM
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
To 87 L98 sensor locations
