how hard to lower front
Old May 4, 2002 | 05:16 PM
Kizmo's Avatar
Kizmo
Default how to lower front
What needs to be done to lower the front of a 95 LT1? Any good tech tips would be appreciated.
Thanks! Kizmo :cool:
[Modified by Kizmo, 2:37 AM 5/5/2002]
Old May 4, 2002 | 10:38 PM
Kizmo's Avatar
Kizmo
Default Re: how to lower front (Kizmo)
:confused:
Old May 5, 2002 | 12:18 AM
6spd89's Avatar
6spd89
Cruise-In II Veteran
It is a bunch of work!!!!!!! I just installed new poly bushings in the
front and DID NOT remove the spring( didn't have to),but i would
have to had the car at least another 10 inches higher. I was about
a foot and a half on jackstands. Check the tech tips for front spring
removal. If you take out the spring,you might upgrade your susp.
Matt
Old May 5, 2002 | 12:24 AM
Springer's LT4's Avatar
Springer's LT4
Cruise-In III Veteran
Default Re: how to lower front (6spd.89)
It's not easy... as said above.... front spring needs to come out... but the effect is so worth it! :yesnod: (see sig)
Old May 5, 2002 | 11:28 PM
Kizmo's Avatar
Kizmo
How high should the car be before I attempt this project? You can only get jack stands so high before it gets down right scarey. :eek:
To how hard to lower front
