Freon level over 100psi ??
Old Oct 18, 2011 | 04:49 PM
derekguzz's Avatar
derekguzz
Default Freon level over 100psi ??
94 6pd,..My ac was working fine the other day. Today's outside temp was a bit warmer (84)so turned it on. The A/C is not engaging. I don't feel the drag I usually do when I run the A/C..I checked the freon level with the gauge from the autozone ect stores I have had for years (checked with 3 diff gauges) and I am reading over 100psi. Any ideas?? The A/C worked great last week. Over filling would keep the compressor from kicking on.
Old Oct 19, 2011 | 11:12 AM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
The pressure when the system isn't running doesn't tell much, other than there's freon in the system. You need to figure out why the compressor isn't engaging. Do you have power to the compressor? To the pressure switch?
Old Oct 19, 2011 | 11:16 AM
derekguzz's Avatar
derekguzz
I will check when it stops raining !
To Freon level over 100psi ??
