'93 passenger power window switch
Old Oct 19, 2011 | 04:49 PM
93annivette's Avatar
93annivette
1st Gear
Default '93 passenger power window switch
The power window switch on the passenger door doesn't work. The power window switch on the driver's door will operate the passenger window however. Because of this I'm guessing the switch is bad, not the motor. One repair procedure I read about indicated a trim tool was required to pull off the switch. Is this correct and if so where can I get one- Autozone didn't have one and suggested Carquest-
Old Oct 19, 2011 | 07:06 PM
whitenow's Avatar
whitenow
Default On my 94 special tools not really needed.
If you are adventurous, you can carefully pop the switch up. It should just be held in place by spring clips.
To remove the door panel, the plugs along the bottom of the door panel pop out, the screws in the interior door pull pocket and release handle bezel need removed.
The switch itself probably just has gunked up contacts and could be cleaned and reused.
I'm not sure just how different the 93 and 94 are, but they definitely have different toggle covers. 94's are black and the housing uses white lettering, 93's use grey toggles and orange labeling, I think.
If you'd send me your switch, I'd see if I could repair it, you just pay shipping. It'd be educational for me.
Old Oct 19, 2011 | 08:24 PM
sailorsteve's Avatar
sailorsteve
That switch can be pried out with a flat blade like a stiff putty knife. Use a rag or something under it on the door panel to be sure the door panel isn't damaged.
To '93 passenger power window switch
