Emergency brake light
The switch is not broken. I took a wire and hooked it to the positive terminal of the battery. Tested the wire that hooks into the switch and the E-brake light turns on, as well as the SES light which i thought was weird, but at least I know everything from that point is good.
So can a switch just go bad by being old? metal qualities not good anymore?
I just looked at mine and found a LOT of dirt, dust and hair down in there. I couldn't see the switch itself.
Taking everything apart and cleaning will probably help.
