Oil spew from dipstick
Old Oct 23, 2011 | 01:55 AM
oldalaskaman's Avatar
oldalaskaman
Originally Posted by TRACKMAN2
we were thinking of running a vacumme pump on 7 3/4......they run them on the scca t1 ls motors they say they gain quite a few hp.....
this is good info
Old Oct 23, 2011 | 05:38 AM
93VettePilot's Avatar
93VettePilot
This is pretty normal on LT1's to push the dipstick out of the tube. I've had two different LT1's and it happened on both of them when you went above the factory redline rpm. They aren't vented very well.
Old Oct 23, 2011 | 08:20 AM
RedTRex's Avatar
RedTRex
Wow....lot's of discussion.
It's pretty much stock, but has long tube headers, hi-flow cats, and magnaflows. 87k miles.
Just checked/reset timing yesterday.
Cap on the tube may help, but that doesn't solve the problem. It doesn't leak from the factory so why now?
Old Oct 23, 2011 | 08:37 AM
87 vette 81 big girl's Avatar
im not fighting with you ive heard this from a lot of guys i just find it hard to belive i could make enuff vacumme to help seal the rings being there like a million psi on the piston side...how does it help...??? asking
George,
Crankcase evacuation pumps are used with low tension to medium tension piston ring sets typical.
And with drilled gas ported pistons.
You have to work closely with your engine builder & follow his advice.
You are high speed road racing.
Much different from drag racing or high performance street driving.
Unless you engine is built & setup right for you racing application,
It will fail in short order.
Stick a drag race engine in your Road race C4,
it will fail likely very soon.
Your engine has to built to last for the long run.
At least 1 year of high speed road racing operating over a very wide power band & ran on the ragged extreme much of the time to win races.
2nd or 3 rd place finishes get old by half season.
Crossing the finish line 1st is where its at..................
Brian
Old Oct 23, 2011 | 02:26 PM
Crepitus's Avatar
Crepitus
Its very possible The Fed approved breather system falls short when used on the track.
Old Oct 23, 2011 | 02:45 PM
cv67's Avatar
cv67
St. Jude Donor '05
I would run a hot leak down test
This.
Dont count on a vacuum pump giving you results you can feel.
Real high rpms/thin ring pack may help some
Old Oct 23, 2011 | 11:17 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Originally Posted by JackDidley
Hate to say this. Your motors tend to self destruct. He needs to resolve the problem.
Ouch!
Old Oct 23, 2011 | 11:47 PM
TRACKMAN2's Avatar
TRACKMAN2
still bettin on the cap
Old Oct 24, 2011 | 12:01 AM
TRACKMAN2's Avatar
TRACKMAN2
i dont think you have a real problem high rpms causes it to puke...aside from what is said here it is my experience that the crankase pressure evac system is inadequate. look at the tennie little hoses that vent the system....if you do have blow by 87k miles it is not imposable to have some worn rings. there isnt a lot you can do but rebuild exept put a breather and a catch can with vent to get the press out... have you wooped on it? how often? enuf press to pop the poorly sealing dip stic tube isnt any thing to worry about you can do a compression/leakdown test but seriously cap it and forget it!!!!!! the ls dipstics have a posotive seal o ring snaps into the tube there dip stic is spiraled to keep oil from creaping up the tube if you had that on there it wouldnt puke...or pop up !!!!
Old Oct 24, 2011 | 12:09 AM
TRACKMAN2's Avatar
TRACKMAN2
Originally Posted by 87 vette 81 big girl
George,
Brian
note made thanks
Old Oct 24, 2011 | 08:57 AM
RedTRex's Avatar
RedTRex
Think I am going to buy one of the flexible sticks from Jegs/Summit.
Also think I will do a comp test - it's good info.
Old Oct 26, 2011 | 08:54 PM
RedTRex's Avatar
RedTRex
I sure feel like a dummy.....I rechecked oil level and it looks like there about 1 extra quart in the engine.........wow, thought I had confirmed this was okay before. Sooooo, guess I will change and fill correctly as well as buying a new dipstick since the top of my tube is bent. I feel better that it looks like I found the cause nonetheless....
Old Oct 26, 2011 | 09:28 PM
  #33
JackDidley's Avatar
JackDidley
If its over full be sure it does not have gas in it. Bad FP regulator can dump gas into the crankcase. Bad injector can do this too.
Old Oct 26, 2011 | 09:32 PM
  #34
cv67's Avatar
cv67
St. Jude Donor '05
Ventilation systems are fine too much crankcase pressure (worn out) can cause it. Start beating on a high mile motor and these things happen.
Old Jan 18, 2012 | 08:23 PM
  #35
RedTRex's Avatar
RedTRex
Just to follow up on this: Problem solved.
I had purchased an oil catch tank and while planning installation.....I noticed the hose on the passenger side seemed too small as it was stretched to fit on the throttle body fitting. The the end going to the 90 degree fitting into the valve cover had a hose clamp which was obviously squeezing the heck out of the hose. I loosened the camp and when I pulled it apart it was a 1/4 barb fitting - WOW. no wonder, and the clamp was probably squeezing the hose shut (or close too it).
I replaced the vent fitting and hose to 1/2 and no more oil spew. Thank God!
Old Jan 18, 2012 | 09:45 PM
  #36
JackDidley's Avatar
JackDidley
Cool !!
