After hauling this kit around for 10 years I finally found the time to install it , followed the instructions to a T and everything seems to be working like it should except for an over heating problem . I recently drove it 25 miles , 45-55 mph and no problem went up to 1/4 on the guage came out from shopping after 45 min. started it up and it went up to 1/2 and stayed there almost home , went down a bit after I fan the heater full blast !!
I took this run after putting in 1 gal, of anti freeze , water wetter, and distilled water , this did seem to help as I always ran 100% or close to it as I once was told anti freeze had a higher boiling point but have been corrected , I think .
Think I need someone that knows more then I do and Paxton never got back to me
I don't have a Paxton - I have an ATI but I am not following your problem. I have a 90 also and my temperature guage goes about half way as that is about 195-200 degrees (roughly) which is the normal range for my 90. Why do you think it is overheating again?
However, assuming I misunderstood, I installed a DeWitts radiator, Edlebrock hi volume water pump and went with a 180 stat, and, most importantly, went with a tune that turned on the fan earlier to match the stat.
If you are running the stock tune, your A/F ratio can be too lean which would lead to overheating. I recommend a Moates Ostrich to help with your tuning needs. I know that when I ran the stock program, it seemed to run fine for shorter trips put a 2 hour drive it overheated VERY badly for me.
You definitely need a BIN file that enriches the fuel. Larger injectors might also me necessary.
How much boost you getting out of it?
I have a new stock rad
Hi flow Stewart water pump
ajustable fuel preasure regulater set at 38 lbs
new 24lb injectors
I was running a 160 thermostat never went over a 1/4 on the guage , also never had heat but no big deal here in FL
Paxton's kit was for 1990 & 1991 vetts
it came with its own thermostat housing and double thermostat installed this is how it works thermostat is installed in a T center comes from motor to the top of the rad then the other smaller out let with a 75 degree thermostat ( 2 in one ) goes to a T installed on the bottom hose with a hose ( size of a heater hose ) goes to that T .
I put it back to stock but did not help so reinstalled it and tried the water wetter and 4 quarts of anti freeze topped off with distilled water and that has helped .
it does seem to cool down after the fans kik in but I think they are coming on late , don't know how to fix that other then a hot wire and a switch in the car .
The kit also came with a water alcohol injection system think something is wrong the water bag was filled up with air when i got home .
think they said 6-8 lbs bost .
I have a friend with a OBD1 scanner and have been told I need to do this but he has been busy , I have a cable for my lap top and down loaded a couple of free programs but could not get them to work
6-8lbs of boost, you think?
Whats your air fuel ratio when cruising? at WOT?
The H20/Alc setup will be to help with Knock. Is it safe to run without that working correctly?
I'm not trying to be an *** but these are questions that really need answering if you don't want to end up breaking things.
Adding boost to a car without checking the Air Fuel Ratio and Knock readings is only ever going to end in tears.
Things to consider that will create heat -
Fuel to lean
Timing Retarded
Heatsoak from hot components
Air lock in the cooling system
fuel /set at 38 lbs 24 lb injectors
Timming retarted /was set at 10 degrees BTC kit calls for 5 degrees BTC
Heatsoak from hot components/not sure what you mean
Air lock in the cooling system / I have run it off and on several times let it cool down and refilled it to the point it does not go down any more .
You're in Florida. Freezing shouldn't be a problem. Run distilled water with a bottle of water wetter. It'll run cooler than with your gallon of antifreeze.
Well I have considered doing without the antifreeze but one of the fellows on here was able to get my laptop hooked up to scan whats going on ,
Timming is to high at WOT
running way to rich at WOT
suggesting a good tunner nere by here in FL. nere the Villages and someone to burn me a new chip
Someone must have tuned your car and jacked up the timing and fuel.
Well ya never know what a previous owner might of done , I did a lot of bolt on stuff but have removed most as to the Paxton instructions ! had a hyperchip but removed that ,car ran well but they can always be better I kind of lost intrest when my friend installed a 502 in his 86 , hooked everything up including AC with no body changes 200 MPR, car has a tag, the ZR1 they should have built ! he loves to spank Porsche
I don't know if this might through a munky wrench into the findings but I did have problems with the 02 sensor so I installed a 2 wire pre heat 02 sensor it is threaded into the collector pipe of the headers as they where not getting hot enough to operate the stock 02 sensor.
Is there a tunable ECM that would work for me or is that big buck stuff ?
