'92 will only start and idle after a rain
Old Oct 24, 2011 | 09:04 PM
ambassadorgodzilla's Avatar
ambassadorgodzilla
Default '92 will only start and idle after a rain
1992, automatic, base model, 65,000 miles, has become impossible to start without stepping on the gas pedal while cranking, then will BARELY idle (if it does) when you take your foot off the gas pedal. Idles under 500rpm on the dash tachometer. Once the car has warmed up it gets better, And will fire immediately without touching the pedal. Only code stored is 43.
But here's the kicker: if it has rained, It fires up like a champ from a cold start, no pedal help, idles/runs fine.
No garage. Driveway car. Haven't had the cover on it since all this started, as it WAS my daily driver.
Free beer for the winner! Thanks, Eric
Old Oct 25, 2011 | 08:11 AM
ddahlgren's Avatar
ddahlgren
You have 2 choices clean the throttle body and IAC and check temp sensors or if you don't have time to do that get the hose out and water the car for 30 minutes before starting..LOL
Old Oct 25, 2011 | 08:16 AM
ambassadorgodzilla
I'll try the cleaning and testing... can't carry a garden hose everywhere I go!
Old Oct 25, 2011 | 10:24 AM
1963SS's Avatar
1963SS
I may be off base here but if you have an open knock sensor a code 43 will be set. As a by-product of the open KS the PCM/ECM will retard the timing to a preset amount. Retarded timing, if far enough, will make it hard to start. The rain thing throws me so just disregard it. I believe the Knock sensor "talks" to the Electronic spark control module to make this happen. If the ESC doesn't talk to the ECM the max retard will occur. Usually about 20 degrees.
1) Open or shorted knock sensor
2) Loose knock sensor
3) Excessive mechanical noise within engine
4) Improper or incorrectly installed PROM or CALPACK in the ECM or defective ECM
5) Intermittent open in the EST line to the ignition module
Old Oct 25, 2011 | 11:14 AM
tunedport85inject's Avatar
tunedport85inject
[QUOTE
5) Intermittent open in the EST line to the ignition module[/QUOTE]
According to the shop manual, code 43, trouble chart- all these condition are related to a bad idling or stall or hard start up.
If a noisy engine produces excessive noise during crancking, knock sensor,as a detonation event,send to EST a signal,EST drops voltage to ECM terminal B7 under 6 v.,istantly ECM retard timing and you have an hard start up
Old Oct 25, 2011 | 11:18 AM
RedTRex's Avatar
RedTRex
Can't ignore the rain factor.....the air becomes a bit denser/cooler during rain. I almost think it's running rich and the denser air helps. Possibilities include, FPR, MAP sensor, vacum leak.
....or maybe the denser air allows for more fuel which helps with the very retarded timing.
Old Oct 25, 2011 | 12:51 PM
ddahlgren's Avatar
ddahlgren
You have a very rare C4 one that likes rain and cold..LOL
Old Oct 25, 2011 | 12:53 PM
ddahlgren's Avatar
ddahlgren
Why not clear the code and see if it comes back... History is just that and you have no idea of when it was set if you have not checked in a while such as before the problem and they were clear then. It would have been real handy if GM included a counter that kept track of how many times a code was set only one byte of info for up to 256 times..
Old Oct 25, 2011 | 01:19 PM
1963SS's Avatar
1963SS
Sure you can.......watch this..................................Ig nored. All Done!!
The biggest clue would be the code 43. That can easily be the cause of his symptoms.
Maybe he could sprinkle some water on the Opti and make the hard starting go away. Add a "T" to the windshield washer line, run a separate hose to just below the water pump, tie it aff and just and clean the windows before starting. Don't really try this. I would hope you know better but there have been some very.......uh............. unformed folks on the forums.
Old Feb 26, 2012 | 01:26 AM
ambassadorgodzilla
Replaced IAC and she purrs again. No codes anymore. Thanks for all the help everyone.
Old Feb 26, 2012 | 02:20 AM
oldalaskaman's Avatar
oldalaskaman
so...first you're sprinkling prozac, then you're sprinkling water, this could end badly.
To '92 will only start and idle after a rain
