after noticing one of the back wheels radial (up and down) movement in the air and recalling no movement on that same wheel on the balancer, i then checked the hub diameter on the wheel compared to the hub center diameter on the wheel bearing and saw there was a gap. I then sought out some center mount wheel adapters. i put them on and had an immediate difference. no vibration at all. before my vibration was from 55 on, now the car runs vibration free at all mid to high speeds. the problem was that the previous owner didnt have the adapters on the car-mustve been lost in other tire services before selling me the car. i am blessed to be a mechanic because if i had to pay mechanics to fix the problems i had with this car, i wouldnt be able to afford it. so anyone else with aftermarket wheels and having a hard to find vibration, first check to see if you have hub center adapters.
the typical or standard wheel adaptor is bored with plenty of room for a hubs center ring to fit thru it. This makes the adaptors fit and balance 100% dependent on how well the lugs fit in the wheel and how well the wheels fits against the hub...It does not always work. This leaves the adaptor free to float around a couple mm in any direction on the hub. Not acceptable.
The "Hub-Centric" adaptors are bored to fit the hub exactly and have a centering ring that guides the adaptor to hub center and holds it there. It can;t get thrown off center no matter what.
Hub-Centrics cost about $20 more for each unit for the extra machine work but there is no question in my mind that they are worth every dime of a $80 price for each one. Thats for good ones...You can ID 'centrics' by the raised ring around the center hole. The standard adaptor is just a hole.
The standard adaptor can be found for $30 ea for minimal spacer and common lugs. If its a wheel....spend the money on nice parts that won;t make you crazy.
Are "wheel spacers/center mount wheel adapters" and "hub centric adapters" the same thing? Thanks
wheel spacers are just circular plates that mount in between wheel and hub using the oe lug bolts, usually needing longer lug bolts installed so you have enough threads for the lug nuts, Center mount adaptors and hub centric adaptors are plates that bolt to your hubs and then your wheel bolts to them, they have a raised , machined to the same size as the inside of the wheel, lip , that centers the wheel on the hub and eliminates, movement. for my money , the only way to safely do it, hope this helps
What type of wear pattern would you expect to see on a tire with a rim that was not fitted correctly? I have center only wear that is not from over inflation and I do not belive from excessive burnouts. I also have vibration around 50-70mph. My rims are OE concept ZR1 chrome rims. They are supposed to be exact for my model but now I am wondering. I've had several road force balances done and even tried swapping a couple of the rims out with another new one I bought. I am going to pull the rim off and measure.
I found these wheel hub centric rings. Is this aka hub centric adaptors or something completely different?
