Hard/no start, runs rough
Old Oct 26, 2011 | 04:10 PM
TPFKATK's Avatar
TPFKATK
Default Hard/no start, runs rough
I parked my 88 2 years ago, had a no/hard start at that time. Treated gas with with sta-bil, 1/3 tank. Back to working on it now. Drained what gas I could, looked clear, no cloudiness, red tint. Car hard starts, sometimes no start. Runs rough but will catch and run fantastic, then back to rough.
I have pulled the Denso Iridium plugs, black fluffy deposits but no build up. Wires are good recent Accell. When I first started working on it the fuel pressure was 37 with the needle jumping all around. Would not hold pressure at cutoff. Adjusted the FP regulator to 40. Put seafoam in the remaining gas. Ran it a while and the pressure stayed steady at 40 and held there at least 2 hours after shut off.
I have swapped the maf, new tps, ohmed the injectors (all 17.8-18.1). Fuel pump and filter are maybe 4 years old.
Drove here to work, put in 5 gals of BP 93 on the way. Left the station running perfect but started stumbling/missing pretty bad. Made it to work, turned it off, will not restart, tried every hour and a half or so for 5 hours. Waiting for the wife to bring the fuel pressure gauge.
Thanks.
Old Oct 26, 2011 | 04:56 PM
sailorsteve's Avatar
sailorsteve
Possibly in spite of your efforts there is water in the tank. also possible there is crud somewhere in the fuel system. Two years sitting with ethanol Stabil or not, is a long time.
I would start with basics- when the car will not start, give it a small sniff of ether into the intake, crank and see if anything happens. If the car tries to start, you have a fuel problem. If no reaction, check a plug wire for spark while cranking but not starting. If you have an induction-type timing light, it will be easier. Once you know whether you are lacking fuel or spark, you can go on to step 2.
Old Oct 26, 2011 | 06:46 PM
TPFKATK's Avatar
TPFKATK
I figured since I was chasing this problem way back when there was little chance or water in the fuel. Figured wrong. Drew about 7-8 ounces of gas through the FP test gauge and there was about a tablespoon of water in it. I guess drain the gas, clean out the tank and change the filter.
Thanks!
Old Oct 26, 2011 | 08:41 PM
sailorsteve
Thanks!
The tank could have collected water by condensation over the two years it stood idle. Also, since you were chasing the problem before you parked it, you may have had water in the tank then. Years ago, I had a 1983 Audi. When it was two years old, I drove it home one day, it coughed a couple of times in the driveway, and after that it refused to start. Eventually towed it to a shop, where they drained, IIRC, a couple of gallons of water out of the tank. I had just filled up that day, and the gas station had water in their tank. Turned out to be a major fuel system repair job.
Glad to hear you found the problem.
Old Oct 27, 2011 | 04:41 PM
TPFKATK's Avatar
TPFKATK
These are GALLON jugs
To Hard/no start, runs rough
