89’, 160k miles. I am the original owner. Wheel bearings are original. Car has developed a slight whining noise, seems to come from driver side rear after about 40 mph. Jacked that wheel off the ground and there is a little in and out play, top to bottom. No such play in any other wheel. Nothing obvious from visible inspection around brakes and knuckle. I am thinking a bad wheel bearing on that wheel. Do you think I am right on the wheel bearing or have other ideas?
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Get a socket for the axle nut (I think its 36mm)
take the cotterpin out and the castelatted cover.
Tighten axle nut IIRC it should be 165 lb/ft.
Now check for play again.
Probably bad bearing, because when they start to seperate you can tighten the nut because it backs off a tiny bit.
When I did mine the first time a few years ago the original bearing came off in two pieces.
Some play is acceptable. Usually if a wheel bearing is making noise, it'll be louder when that side is loaded. Anotherwards, does it make more noise when you turn left vs right? If so, it most likely is the bearing. If not, might want to change the diff fluid and check ujoints.
When you check the spindle nut, if it's finger tight or really loose; that's a sure sign the bearing is toast.
Thanks for the comments. I should have mentioned that the noise does change if turning right or left or breaking. The u joints seem tight but I am ordering new ones along with the new wheel bearing. A 36 mm socket is on the way and I will check how tight the axel nut is as soon as it arrives. I understand that I can drop the half shaft by removing some of the connections to the knuckle for replacement of the u joints. http://forums.corvetteforum.com/c4-t...g-removal.html Seems like that will also make it easier to get the torx bolts holding the bearing unit in place. I have also ordered a T55, can anyone confirm that is the correct size to remove the wheel bearing unit?
I can confirm that the three bolts in the back of the bearing are T55s. By taking the axle shaft out it DOES make it easier to do the bearing and the Universal joints at the same time. Don't forget that famous $8 teflon coated washer that keeps your axle from making a popping noise when you take off. It goes between the spindle shoulder and the back side of the bearing. There's a thread on that topic here somewhere.
When I did my bearings there was no washer there, so I had to go back in weeks later to put the washer in. It makes a difference!!
Good Luck!
Good Luck!
Thanks for the confirmation on the torx and the heads up on the washers. I found the threads you mentioned and will pick up a couple of new washers
Those washers IF they are the correct size, are used to load the tension on the inner bearing race so that part is what is being held by the nut. Then the outer race and bearings can roll freely without being in a bind. If the Washer is not there, the nuts might press on the whole assembly and add some tension to the bearings or side load the bearing assy cauing premature wear.
When you pull the hub assy and remove the 3 torx bolts, consider going to a grade 8 hex. The torx need some thread locker and later can be difficult to remove. The hex has plenty of room for sockets and being a G8 will be more difficult to strip the head.
I had 2 of 3 torx fall out from not having any thread locker applied...almost lost the wheel.
I had kind of a moaning sound going around corners on one side, and changing the rear-end lube (and adding the GM posi additive) made it go away.
I note McMaster Carr indicates that their torx are equivlent to Grade 8. http://www.mcmaster.com/#torx-socket...screws/=eqbk6f Wonder what the stock ones are? I have not taken this thing apart yet, anyone know the size on the torx bolts?
