383 Stroker Logfile!
Old Oct 31, 2011 | 12:00 PM
cleon123's Avatar
cleon123
Default 383 Stroker Logfile!
Can someone look at this logfile and tell me what's wrong with it?!
https://rapidshare.com/files/3462102449/AutoLog_001.uni
Thanks!
/Jocke
Old Oct 31, 2011 | 02:01 PM
dan_t's Avatar
dan_t
Its really hard for me to make sense of this log to be honest.
Your fueling seems all over the place. And deffinately wild splits between banks ie at a couple of points you have one bank BLM 108 and the other BLM 160. That indicates fully rich and fully lean.
Unfortunately I think all we are seeing with your BLM readings are the missfires. Missfires will show as a LEAN condition and the ECM will add fuel to try and cure it.
Also I suspect that your TPS is not reading accurately. I beleive you probably went WOT a few times but your only showing 60% TPS. I think you need to check the voltage at the TPS directly as that could be causing all sorts of issues.
Old Oct 31, 2011 | 02:11 PM
cleon123's Avatar
cleon123
Yes, it's crazy how much it splits! The strange thing is, that the TPS is brand new!
To 383 Stroker Logfile!
