I've got a nasty creak which seems to be coming from the steering rack. If I have someone turn the wheel left or right, with the wheels on the ground, it seems to be coming from the pinion area. I can feel it if I grab the rack around the pinion. I'm planning on replacing it but figured I'd run it by you guys in case someone has some better info.
Also, has anyone found a good source for a rebuilt, 2 turn rack? Only place I've found one is ebay.
I thought long and hard about buying a rebuilt unit from Napa or Advance, but I heard too many stories about having to go through two or three before finding one that was done right. As a result, I decided to send mine off to TurnOne for them to rebuild my original unit. Pricey, and it took a couple of weeks, but worth it, in my opinion.
Have you tried Rock Auto? I know they had some, both types on close out, those are gone but they may have some stock at regular price, which for them is generally pretty low.
I called Turn One - $360 and 7 to 10 days to rebuild. I looked at the rack again yesterday and may have lucked out. The creak was coming from the mounting bolt to the cross member. I re-torqued the mounting bolts and the creak is gone. We'll see what happens.
llong66, Rock was the first place I tried and have checked back several other times, they had nothing in stock. Checked again after your post and they had 1 in stock, but never heard of the brand.
You might want to flush out all the old power steering fluid and replace with a good synthetic. I did mine recently and it quieted down the P/S system significantly.The flush is easily done with the front up on jack stands and the wheels off the ground. Here is a write-up on the flush process.
