C4 re-born in NY
Nov 2 first start LT1 383 modified Holley Stealth Ram.. very impressed with first start.. next spring will be a blast... Any track events scheduled
Will be posting Vids soon
The hood will need to be cut.. and fab in a scoop.. I want 100% benefit from my 1206 port HSR
the build.. program Eng splayed caps, Zero deck, Lunati billet Race 3.75 crank, Callies billet 6.0 rods, aluminum 12# flywheel
SRP FT -.05 forged +.030, 12:1, LE billet custom cam, Isky 6105 springs, Patriot 195rl converted Gen 1 heads, MLS .040 Gasket, LS7 lifters, 1.6 S.S. RR, HSR converted 1206 ports, 50# inj, custom FF rails
OBX long tube headers,straight through
I just started switch & constants.
next scan tune. then DYNO
now I need to scan tune. then Dyno tune..
http://www.youtube.com/watch?feature...&v=qM1nhwjqXho
'Got quite a bark, can't wait to see how she bites.
SRP FT -.05 forged +.030, 12:2, LE billet custom cam, Isky 6105 springs, Patriot 195rl converted Gen 1 heads, MLS .040 Gasket, LS7 lifters, 1.6 S.S. RR, HSR converted 1206 ports, 50# inj, custom FF rails
I just started the tune. now I need to scan tune. then Dyno tune..
Wow.. 12.2 compression ratio!! Is that why you used the MLS head gasket?
Thank-you, I already had theses heads dialed on another build.. the conversion is not extremely hard.. but I sent them out $500. Slightest surface, coolant port welded and cross drilled for the oil return.. I believe this is a Better choice over the only 64cc AFR 2,300 LT1 heads.. The HSR welded on material to make a 1206 port that had to match the heads...and welded the front coolant passage shut...
And yes. can't afford using a stock gasket on this setup..
Huh that's funny I had these inj and tuned perfect on my 358 build with .125 domes same heads 11:1 and HSR.. that combo was making 450+ HP... You think maybe with this combo I lost .. HP I'm pretty positive this is way over 500 HP..
Also, do you have any pictures of the hood or scoop etc?
Nice work
