i want to change into roller rockers kit
anybody can tell me what ratio is the best for a street use.
1.5 or 1.6 ratio ??
L98 or LT1??? If you are going with the 1.6 rr you really need to change more than just the rockers. There is a good article in the April issue of Vette magazine where they did some tests with a 383.
1.5s are a simplier mod and provides a good performance increase for the $$$ spent.
If you don't want to run taller valve covers w/the roller rockers you have to cut the drip tabs out of your valve covers. I run Comp Cams roller rockers and this was in the instructions. I used a Dremel tool w/a thin cutting disk to cut them out, then ground them smooth. After the fight of removing the valve covers everything went smooth. I'd rate it as a two six pack job. Good luck
