Door Panel
Old May 6, 2002 | 10:24 AM
Jim D's Avatar
Jim D
Default Door Panel
I have to take the door panel on the passengers side off ,the screw for the door pull came out. Are there any hidden screws ,or just the ones you see ,any tips thanks Jim
Old May 6, 2002 | 11:15 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Default Re: Door Panel (Jim D)
Remove the door lock slide (pry it up and out in the unlocked position)
Bunch of screws around the interior side of the panel.
1 screw above the latch switch, sometimes its hard to see it.
2 screws thru the door handle bolster
If you have to remove the inner door panel (its silver, I think its sheet metal)
Then be prepared to curse a little bit.
There are about 8 screws holding it in and one 7 or 8 mm bolt
Once you rmove all of them you can wiggle the panel down and forward to release the top front, then down and back to release the rest of the top portion. Pull up and it will come free of the bottom.
When reinstalling, make sure the rod from the powerlock selenoid hooks up with the door lock rod, or your power door locks won't work. Reinstalling the door lock slide is a PITA.
Good luck :cheers:
Old May 6, 2002 | 11:17 AM
DHealey's Avatar
DHealey
Theres about 6 on the carpet section, 2 on the door pull, and one on the door jam side. Mine also has a velcro strip on the top left side as you face the panel.
But no screws are hidden.
Also, the little plastic retainers for the screws are still available from GM. $0.98 each list.
[Modified by DHealey, 10:22 AM 5/6/2002]
Old May 6, 2002 | 01:36 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
All together on my 92 the passenger side door panel was attached with 13 screws.
Three are hidden:
1 for the grab handle is behind the power window switch
1 under the courtesy light
1 under the slide lock
Have fun!
:cheers:
Old May 6, 2002 | 02:45 PM
Goody's Avatar
Goody
Default Re: Door Panel (Blue 92)
Was a trip to do the first time, but not so bad any longer. Make sure you put the vapor barrier back on. You may not think it is needed, but it is. Water and electrics don't like each other. :seeya
Old May 6, 2002 | 03:49 PM
SonnyinVA's Avatar
SonnyinVA
Default Re: Door Panel (Goody)
watch out fo that one behind the door lock sliding thingy!! i always forget about that one, until i can't figure out why the panel won't come off...
To Door Panel
