Do I Need a New Prom?
Old Nov 7, 2011 | 05:03 PM
ittlfly's Avatar
ittlfly
Default Do I Need a New Prom?
Hey Guys,
My buddy has a 1993 LT-1 Auto. KOEO (enging stone cold) both fans start up but the car won't start. Key off then back to 'on' fans not running and engine starts. We chased the rest of the fan system and it is in good working order, relays etc. So put his prom into another ECM and it does the same thing. We are now thinking a bad prom.
Can his be reflashed? If not, where can we get another one?? Any ideas?
Old Nov 7, 2011 | 05:09 PM
dan_t's Avatar
dan_t
A prom error will cause the fans to run.
Old Nov 7, 2011 | 05:33 PM
ittlfly's Avatar
ittlfly
So is there a fix or????
Old Nov 7, 2011 | 06:14 PM
ittlfly's Avatar
ittlfly
Anybody used Ed Fast "Fastchip'' proms??? if so any input on his product??
Old Nov 7, 2011 | 09:27 PM
dan_t's Avatar
dan_t
If your using a stock prom and it is causing a problem then the only way around it would be to replace it. I'm no expert when it comes to the LT1 ECM's though.
Have you read the ECM for any error codes. I beleive code 52 (from memory) is Prom Error.
Old Nov 8, 2011 | 07:05 AM
rodj's Avatar
rodj
It could if you can find someone with the the right equipment to erase and reprogram ( was old skool way )
Current way is to install EEPROM on a custom adapter
Online tuners like PCMforless and other will do a stock tune or any mods you want, like VATS delete , lower fan temps , etc
http://www.pcmforless.com/index.php?...per&Itemid=316
92-93 LT1 have same style removable memcal as the earlier ECM's.
94+ have the sealed alum case version with internal memory that can be re-flashed
Old Nov 8, 2011 | 08:12 AM
ittlfly's Avatar
ittlfly
Thanks for the reply guys. I'll pass all this info along to my friend.
Old Feb 18, 2012 | 10:39 PM
Guitarguy's Avatar
Guitarguy
sounds like on first turn of the key the ecm and i think its called the ccm are not seeing each other. if the digital gages read lo when the fans r running and no start this could be the problem. could be as simple as a bad ground on the ccm. dunno. good luck
Old Feb 19, 2012 | 07:13 PM
ittlfly's Avatar
ittlfly
Up date.....it turned out to be a bad ECM. Since we couldn't locate a known good replacment, we put in a stand alone aftermarket unit for the fans bypassing the ECM completely.
To Do I Need a New Prom?
