Shifter Recommendations ?
Old Nov 10, 2011 | 09:14 AM
C409's Avatar
C409
Default Shifter Recommendations ?
..... The new shift kit in the 700R4 has the automatic shift points way too low for the strip ... gotta shift manually ... the stock shifter can't / won't cooperate as needed ... Whats the best aftermarket shifter for the stock console ? ... I don't expect a bolt-in but wonder if there is one that's easier to fab in and nice looking installed ??? ... pics ??? .............
Old Nov 10, 2011 | 04:06 PM
twin540's Avatar
twin540
Old Nov 10, 2011 | 08:03 PM
rodj's Avatar
rodj
Originally Posted by C409
gotta shift manually ... the stock shifter can't / won't cooperate as needed ... Whats the best aftermarket shifter for the stock console ? ... .
B&M Quicksilver ratchet in mine;
only one gear at a time up or down no matter how hard you shift
http://www.summitracing.com/parts/BMM-80683/
With shifter base mounted to the tunnel floor ,the chrome cover plate sits nicely on top of console ;
BUT shifter **** is way higher than stock which may not suit unless shaft cut down.
I don't mind it high because it is right there as your hand drops of the wheel for spirited shifting
Very functional but looks a little odd
Old Nov 12, 2011 | 10:03 AM
mseven's Avatar
mseven
this should get you started:
http://forums.corvetteforum.com/c4-t...s-to-date.html
Old Nov 13, 2011 | 01:19 AM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
Is scrap the auto-craptic in favor of a sick speed with a b&m...
Old Nov 13, 2011 | 09:17 AM
RichS's Avatar
RichS
Buy a governor recalibration kit. My 700R4 shifts at 6200.
To Shifter Recommendations ?
