No Start After Storage=Starter?
Old Nov 10, 2011 | 01:48 PM
armybyrd's Avatar
armybyrd
Default No Start After Storage=Starter?
Finally had a chance to make it up to my '88 C4 in storage-put a new battery in though she wouldnt even turn over. It sounded as if the battery terminals werent sercure though I made sure a few times that they were. I knocked on the starter and even put a socket on the crank and sure enough shes not locked up or anything. I cant hear the starter solenoid so Ive narrowed it down to the starter which is the original delco. Actually just got back and Im about to check with my FSM to see if it could be anything else. Any input? Btw with the key in the on position oil pressure was around 8-11 psi-does that sound about right?
Old Nov 11, 2011 | 12:43 AM
Cliff Harris's Avatar
Cliff Harris
The starter solenoid doesn't take much current, so it should work unless the battery is REALLY low. You say you can't hear it, so it appears that it isn't getting any voltage.
The VATS module disables the starter if it doesn't see the correct key resistance. There is a starter relay involved there, which applies the voltage to the solenoid. That relay could have a problem.
I know that some years (I don't know when) will flash the SECURITY lamp if VATS fails. Some good VATS info here: http://www.vatssucks.com
You've got oil pressure without turning over the engine? Could be a bad oil pressure sender or gremlins in the dashboard. Probably just a distraction at this point and something to come back to later.
Old Nov 11, 2011 | 12:48 AM
armybyrd's Avatar
armybyrd
Never had any Vats/no start problems before and Im not seeing the flashing sercurity light. Might end up going up there with a multi meter today just to see-how much voltage should the solenoid be getting? When I put the key in the on position yes the oil pressure gage goes to around 8psi and jumps around a little bit-is that normal? I figured you needed oil pressure to start the car.
Old Nov 11, 2011 | 03:34 AM
weaselbeak's Avatar
weaselbeak
You won't have any oil pressure until your motor is spinning. My vote is for the vats. You could jumper the relay as a way of checking.
Old Nov 11, 2011 | 03:40 AM
armybyrd's Avatar
armybyrd
Is it a relay specific to VATS?
Old Nov 11, 2011 | 04:05 AM
weaselbeak's Avatar
weaselbeak
Yes
Old Nov 11, 2011 | 04:06 AM
armybyrd's Avatar
armybyrd
Wheres this relay at? Is it with the rest of the fuses or?
Old Nov 11, 2011 | 10:05 AM
armybyrd's Avatar
armybyrd
Update: So I just got back from messing with my Vette. I tried to get her to turn over a few times and once the starter kicked in for a sec then nothing. I disconnected the battery and hooked it back up and tried a few more times and bam she fired up. A few of my dash lights dimmed for a few secs though-I think its just the bulbs going back. Alternator is new and my charging system is good. Car seemed to smoke a lil bit but Im guessing this is expected from sitting for so long.
Old Nov 11, 2011 | 10:19 AM
aminnich's Avatar
aminnich
Time to clean the battery cable ends maybe?
Old Nov 11, 2011 | 11:07 AM
armybyrd's Avatar
armybyrd
Its a new battery and terminals were replaced before I left. I let her idle for a little while and shut her off to see if she would start up-good to go.
Old Nov 11, 2011 | 11:18 AM
dclafleur's Avatar
dclafleur
Might be a good time to check your grounds too, check for corrosion and what not.
Old Nov 11, 2011 | 12:13 PM
jfb's Avatar
jfb
Starter motors draw a lot of current (my 87 draws 240 amps) and you MUST have a low resistance cable connection to the battery for it to deliver cranking current. If you replaced the cable ends that connect to the battery, I would check them carefully. If you had bad cable ends, it would have been much better to replace the entire cable.
Old Nov 11, 2011 | 06:04 PM
weaselbeak's Avatar
weaselbeak
vats can definitely be hit or miss though. Mine would start for a week and then one day when you're coming out of the gas station-bam, nothing. Wait 5 mins or so and then it'd start right up.
To No Start After Storage=Starter?
