On to next problem! Tapping noise.
Old Nov 10, 2011 | 08:13 PM
Bredd1's Avatar
Bredd1
Default On to next problem! Tapping noise.
I can hear a tapping noise that seems to be coming from either the valves or exhaust manifold. The sounds seems to be louder when I adjust the timing. I thought it might have been that the lash on the valves were not adjusted correctly after I replaced the head gasket, so I went back & set them again but I'm still getting the noise. Any suggestions?
Old Nov 10, 2011 | 08:35 PM
weaselbeak's Avatar
weaselbeak
could you explain how you're setting them? any vids?
Old Nov 10, 2011 | 08:51 PM
1963SS's Avatar
1963SS
Did this tapping start after you replaced the head gasket? Take a piece of hose and stick it in your ear. Take the other end and move it around down by the manifold. This is a great stethoscope. Listen for exhaust leaks. Rule out the exhaust first. Then.....how did you adjust your valves?
Old Nov 11, 2011 | 05:54 AM
Bredd1's Avatar
Bredd1
I adjusted the valves as explained in the manual for motors with hydraulic lifters. With motor at TDC, I used my thumb & index finger to twist the lifting rod as I adjusted the nut on the valve until there was drag in twisting the rod, then turned nut another 1/2 turn. I did this for each cylinder in firing order.
Old Nov 11, 2011 | 07:54 AM
WW7's Avatar
WW7
Next time you adjust the lifters move the pushrod up and down until all play is gone. This is much easier and more accurate for getting to 0 lash then twisting the pushrod. ...There's a guy on here named "Caldorone" that thought for sure he had a lifter noise. ended up being a small exhaust leak. Even in the video he made it sounded exactly like a lifter, so do like "1963SS" suggested and use the stethoscope method to find out where it's coming from......WW
Old Nov 11, 2011 | 11:01 AM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
I would go to the parts store and buy a mechanics stethoscope. It won't be the last time you use it.
Old Nov 11, 2011 | 11:35 AM
1963SS's Avatar
1963SS
Great suggestion. Harbor freight has a digital stethoscope that looked like a gimmick but it was so cheap I had to get one. It comes with a set of headphones and the mechanical probe coupled to an amplifier. It's not a gimmick. I love it. You can adjust the sensitivity to remove any background noises that you don't want to hear and the headphones do away with ambient noise.
They also have the regular old mechanical stethoscope for about 5 bucks.
Old Nov 13, 2011 | 08:54 PM
Bredd1's Avatar
Bredd1
Ok, I only had a few minutes to work on the car today. I went & purchased a stethoscope as suggested & did a little probing around in the area where I suspected the sound was coming. It turned out that it didn't seem to come from the #2 or #4 valves as I suspected. I checked around the exhaust in that area also but nothing that I could tell. I listened to all four injectors on that side and they all sounded OK. The sound seemed to come from the passenger side but after checking today, I'm not so sure. I plan to do more checking when I have more time to work. Any other ideas or suggested areas to check?
Old Nov 14, 2011 | 07:50 PM
Bredd1's Avatar
Bredd1
I did some more checking today, and couldn't determine anything. I'm thinking that what I'm hearing an exhaust leak. I don't hear it so much while the car is standing and idling but I can definitely hear it when I'm driving. What do you think?
Old Nov 14, 2011 | 08:30 PM
0Paul Ruggeri
Former Vendor
Exhaust leaks are usually louder when the engine is cold and get quieter as things heat up. An exhaust leak will also be louder when the engine is under a load and quieter when you let off the gas.
Old Nov 14, 2011 | 08:34 PM
Bredd1's Avatar
Bredd1
I'm thinking its an exhaust leak at the exhaust manifold collector. Any idea what gasket I need?
Old Nov 14, 2011 | 08:49 PM
qws's Avatar
qws
Harbor Freight $5 ... best investment I ever made
Old Nov 14, 2011 | 09:00 PM
Bredd1's Avatar
Bredd1
I got the stethoscope and used it but I couldn't determine the leak with it. When I got it I thought it was a valve or injector that was making the sound but after I used it to check around the heads and injectors, it wasn't. Like I said before, the sound is not so loud when idling but I can hear it well when I'm driving.
Old Nov 15, 2011 | 12:45 AM
desertmike1's Avatar
desertmike1
Did you have this noise before doing the head gaskets??
Did you have any "head" work done?
Did you "Torque" the exhaust manifolds & collectors, with clean, and lubricated threads. Did you install new gaskets?
You could also Pressurize the exhaust system, with the exhaust side of a shop Vac, and feel around for leaks. A soapy solution also works well for locating small leaks.
Old Nov 15, 2011 | 01:33 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Factory rockers or roller tips?
My roller tips are as noisy as an exhaust leak..
Old Nov 15, 2011 | 04:55 AM
Bredd1's Avatar
Bredd1
I don't recall having the leak before doing the head gaskets.
No, head work was done, other than cleaning gasket face.
Yes, I torqued the bolt, now that I remember, I had a hard time getting to the bolts at the #8 cylinder. I need to re-check those. I used oil to lube the bolt threads. I installed a new gasket at the manifold but not the collector. Any idea what size gasket to use at the collector, everything is stock size?
Old Nov 15, 2011 | 06:43 AM
desertmike1
my LT1 collector does not use a gasket, not sure about the L98.
Go back and check all of the exhaust manifold bolts, I use high temp Anti sieze on my bolts, it won't burn up when it gets hot (rated 2400 f)
To On to next problem! Tapping noise.
Old Nov 15, 2011 | 11:35 AM
0Paul Ruggeri
Former Vendor
L98 manifolds don't use a flange gasket. Be sure the 3 nuts that hold on the flange were tightened evenly.
Old Nov 15, 2011 | 06:40 PM
Bredd1's Avatar
Bredd1
I went through with the stethoscope again to see if I can identify anything but found nothing. I don't think the noise is coming from the engine, thank god! I'm almost sure its the exhaust. Not sure but I think its at the collector on the passenger side. I will plan on checking it this weekend. I don't have much time or daylight in the evevings now that time has changed.
Old Nov 16, 2011 | 02:01 AM
Cliff Harris's Avatar
Cliff Harris
The bolts on my exhaust manifolds get loose about every six months or so. It's always #7 and #8. All the others stay tight.
The first time I had this happen, I would get a rattling noise when I accelerated up a hill. We finally found the problem when I put the car on a dyno so we could load the engine and listen for the noise. One of the #7 bolts was out more than 1/4".
