What have I done?
Old Nov 11, 2011 | 09:47 AM
jb7's Avatar
jb7
Default What have I done?
Ok, have a thread titled cooling issues, was going thru some diagnostics and one suggestion was jumping terminals A and B under dash on my 85' to see if cooling fan would come on, well, did this and heard something happening around throttle body/intake, when i went to start the car afterward, it is like it is bigtime flooded or something, wont stay running, real rough, real smokey, real smelly, its like its flooded and misfiring, please help, it ran like a sewing machine before?
Old Nov 11, 2011 | 10:26 AM
aminnich's Avatar
aminnich
Are you in Atlanta or one of the suburbs?
Old Nov 11, 2011 | 10:32 AM
jb7's Avatar
jb7
off of Townlake Parkway in Woodstock
Old Nov 11, 2011 | 10:35 AM
aminnich's Avatar
aminnich
You are close by then. Unfortunately I have no experience with your year vette or I could come over and help you out with it.
Old Nov 11, 2011 | 10:43 AM
jb7's Avatar
jb7
I appreciate that...it was almost as if when I jumped the terminals it started pumping fuel, it was about 11 hrs. b/w jumping term. and cranking second time, if it was flooded the first time, I fiqured it would have resolved itself over night....
Old Nov 11, 2011 | 10:47 AM
aminnich's Avatar
aminnich
After you reset the computer is it back to running normally now?
Old Nov 11, 2011 | 10:57 AM
1963SS's Avatar
1963SS
Have you tried to start it while holding a little pressure on the gas pedal. There isn't much that can make a noise by the throttle body except the IAC and it could definitely cause your symptoms. Possibly when you jumped the pins you may have inadvertently touched something else and screwed up the ECM's train of thought. I wouldn't know what it could be because it's called ELECTRICAL THEORY for a reason.
Try to disconnect the battery for a few minutes and then reconnect it and see if that helps.
As stated earlier, try to start while giving it a little gas to open the throttle body.
Old Nov 11, 2011 | 11:09 AM
Deepa's Avatar
Deepa
isnt there a way to jump the fuel pump from the ALDL connectors?
IF you have leaking injectors and you jumped the fuel pump (if possible), then your noise and flooding makes sense
Old Nov 11, 2011 | 11:34 AM
SunCr's Avatar
SunCr
By default, jumpering the Diagnostic Link pushes the IAC pintle into it's bore which is what you heard. If you disconnect the harness, it would barely idle (assuming it was warmed up) and that's what's referred to as Minimum Idle. To reset, slightly depress the accelerator and start it. Let it run for a few seconds; then off for a few and when you restart, all should be normal.
Fuel pump relay can be run at Terminal G of the Link - there's really no need to jumper it - it has plenty of fuel; not enough air.
Old Nov 13, 2011 | 12:37 PM
jb7's Avatar
jb7
UNhooked battery overnite, still runs rough and is burning a bunch of gas and smoking, I guess I should have just taken it to the professionals in the first place, it ran fine before jumping terminals A and B under dash...
Old Nov 15, 2011 | 03:29 AM
Cliff Harris's Avatar
Cliff Harris
You did REMOVE the jumper from terminal A to B, I hope...
It sets a bunch of things to fixed settings for diagnostic purposes. You're not supposed to drive the vehicle with A & B jumpered.
You didn't mention if the fan(s) ran with the jumper in place.
Old Nov 15, 2011 | 02:10 PM
jb7's Avatar
jb7
i did not drive it with clip in and no the fan did not run, it turns out that a previous owner had rewired it to ignition, and there was a break in the line, gonna try to wire it back to normal...but there is a problem with computer, when in diagnostic mode it blinks 12 times over and over again, you can barely tell it is blinking, love these old computers, wonder how much a new or reprogrammed one is...
Old Nov 15, 2011 | 03:16 PM
DMheart's Avatar
DMheart
surprisingly inexpensive, but they'll come without the PROM.
One question though comes to mind ....
did you recently run any water into your engine compartment? (cleaning, stuff like that).
Old Nov 16, 2011 | 02:04 AM
Cliff Harris
Code 12 is no pulses from the distributor. It's normal when the engine is not running.
To What have I done?
