96 LT4 Shocks
Old May 6, 2002 | 06:11 PM
365ZUM's Avatar
365ZUM
Cruise-In III Veteran
Default 96 LT4 Shocks
Since I've had my car up on the lift at MORE performance, I've been fighting off all kinds of mod temptations! :reddevil
But, I'm particularly interested in changing shocks. The car has 68k on it now, so it's about that time anyway. I've got the FE1 suspension and I (for one) love the ride quality of it. I'd be interested in just replacing the shocks with new factory FE1 shocks. SO, here is my first question:
What is the part number for 96 FE1 shocks, and who has the best deal on them??
Also, I would be interested in hearing from anyone who has done the same swap, with a different brand of shock.
What do you recommend?
I'd love to be able to increase the handling abilities of the car, while maintaining a soft ride. Thanks! :cheers:
[Modified by 365ZUM, 5:12 PM 5/6/2002]
Old May 6, 2002 | 09:07 PM
365ZUM's Avatar
365ZUM
Default Re: 96 LT4 Shocks (365ZUM)
anyone :confused:
Old May 6, 2002 | 09:18 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
I have been running Koni single adjust. for about 2 years. Most of the time they have been set on firm. The ride is stiff but not bouncy. I like it, but haven't tried adjusting the shocks softer. The factory shocks can be rebuilt by Bilstein. I don't have contact info, but it shouldn't be hard to find in a search of archived topics.
Old May 7, 2002 | 08:37 AM
365ZUM's Avatar
365ZUM
Default Re: 96 LT4 Shocks (93Polo)
I think I've pretty much decided to replace them after the CF Cruise-In. From what I've read, dosen't seem to be rocket science to replace them. After the homework I've done, I've decided between two: Bilstein HD's, or Bilstein Sports (Z51 shock).
I've heard that when added to a base FE1 suspension, the Z51 shocks for 96 arent very rough at all. Can anyone back this up??
Old May 7, 2002 | 09:30 AM
Arisa's Avatar
Arisa
just IM'ed ya.
Neal
Old May 7, 2002 | 12:06 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Not sure the 96s are sprung softer than earlier C4s so it wouldn't surprise me.
[Modified by 93Polo, 11:07 AM 5/7/2002]
Old May 7, 2002 | 01:03 PM
ConeKLR's Avatar
ConeKLR
Cruise-In II Veteran
the 96's are the softest sprung of all C4's. REally the springs is what causes the car to ride hard or not. The shocks control the up and down motion.
Seems like you enjoy the soft ride. So just replace the shocks with new 96 FE1 shocks.
:cheers:
Old May 8, 2002 | 10:57 PM
365ZUM's Avatar
365ZUM
Default Re: 96 LT4 Shocks (ConeKLR)
Anyone else??
I'd really like to come to a decision soon.
Bilstein HD or Bilstein Sport (Z51) - FE1 base suspension
Old May 8, 2002 | 11:33 PM
Zix's Avatar
Zix
Why not have your stock FE1 shocks rebuilt by Bilstein? I just did it with mine (FE1 as well) and it came out great! Firm, yet not harsh...much better than stock
Old May 9, 2002 | 02:20 AM
John Ruy's Avatar
John Ruy
Just took Z-51s off my vert. The ride was Ok. Quite a lot bumpier :boxing than the stock shocks. The worst was some vibration at about 60 - 65. Alignment shop advised I soften the ride and stiffen the sway bar up front. I went with Edelbrock IAS. Good shock. :)
Bought a hard top too, so can't tell you for sure if it was the shock or the hard top that stopped the vibration. But the ride is superb...
Took some getting use to, seemed too soft. But they are there for you when you need them. Keeping the tires on the ground in a turn is important. :yesnod:
I'll keep the z-51s for auto-x, but Edelbrock has my vote. ;)
I do plan to move to a 32mm up front stock is 24mm.
Old May 9, 2002 | 09:13 AM
365ZUM's Avatar
365ZUM
Default Re: 96 LT4 Shocks (John Ruy)
John- were those Z51's true Bilstein shocks? or were they the AC Delco/Bilstein version?
Thanks :cheers:
Old May 9, 2002 | 09:19 AM
MSR's Avatar
MSR
Default Re: 96 LT4 Shocks (Zix)
the "Z51" and "sport" are 2 different versions of bilsteins.
Old May 9, 2002 | 04:07 PM
John Ruy's Avatar
John Ruy
Thanks :cheers:
Bilstein Z51s
You should know I'm lowered 1" and that could make a difference in the ride. :yesnod:
Old May 9, 2002 | 04:13 PM
John Ruy's Avatar
John Ruy
Thanks :cheers:
SORRY, I just walked out to the garage and looked. :rolleyes:
DELCO Bilstein Sport
ordered them from Mid America.
BTW only got 20K before they started leaking oil. :eek:
The stock FE-1 had 60K before they leaked. :U
Old May 9, 2002 | 07:52 PM
365ZUM's Avatar
365ZUM
Thanks John,
I talked with "Jack French" (found his name in a former thread) from Bilstein, and he recommended the Bilstein HD over the Sport or the Z51. He referred to the latter two as "weekend racer" shocks- not what I'm after.
I want a firm, yet absorbing ride (the best of both worlds of course :D ) and he described the Bilstein HD as just that.
SO, I'll be going with the HD's. Thanks alot for the advice!! :cheers:
Old May 10, 2002 | 07:48 AM
gtsyellow's Avatar
gtsyellow
i have a set of 5k mile z51 bilsteins i ordered, drove on and then changed to konis..darn steins are too soft for me, but they are a good deal more firm than a worn shock or the base shock. i'd take $160 shipped for the set. they will be available in a couple weeks. a friend is using them right now while his fx3s are being rebuilt.
To 96 LT4 Shocks
