I am installing a TPI system on a 383 stroker. I will be using the FAST retro kit to control the injectors. I was told by a FAST tech to use 36# injectors. I am having a hard time finding out which injectors will work.
I have seen some the have adapters to make them longer so that they will work. Is there a site or a list somewhere that has brands and part numbers for injectors that will work? There has got to be a few folks on this forum that have larger injectors in there TPI and can list the part numbers and how many pounds the injectors are. Can you buy the adapters separately?
