Cam recommendations
Old Nov 12, 2011 | 11:13 AM
Timo's Avatar
Timo
Default Cam recommendations
Hi, i have a '95 LT with P-1SC and AFR 195 cc etc. Now there is a Comp 503-8, but i don't like it. A Comp 304-8 or 465-8 could be better, but is the 304-8 a computer compatible ? Lunati cam (215/218)has a 115 lsa ? Is this a king ?
Old Nov 12, 2011 | 12:24 PM
tequilaboy's Avatar
tequilaboy
Just curious, what don't you like about the 503? I've always liked mine, with and without blower.
If I were ever to change cams, I think I'd want more overlap and a tighter LSA.
Old Nov 12, 2011 | 01:40 PM
CAJUN C4's Avatar
CAJUN C4
Check out the Comp. Cams XFI268 or 280.
Old Nov 12, 2011 | 08:11 PM
96 lt-4's Avatar
96 lt-4
I would be calling a cam company and having one ground for the blower and your setup.Why run an off the shelf grind when you have updated everything else??
Try Cam Motion or Advanced Induction just to name a few.
Old Nov 12, 2011 | 10:46 PM
THE 383 admiral's Avatar
THE 383 admiral
LE has great LT1 Custom Billet grinds
Old Nov 12, 2011 | 11:08 PM
cv67's Avatar
cv67
St. Jude Donor '05
Erson has some of the nicest quality Billet rollers Ive seen
Dont know about their EFI grinds though.
Should be plenty of off the shelf cams out there dont see why youd need a custom one. Most the time they are overrated.
Old Nov 13, 2011 | 10:33 AM
Timo's Avatar
Timo
I need better idle and lower emissions and better driveability at 1000-2000 rpm (cruising speed). Here is difficult pass a smog test with comp 503. I think i need wider LSA .
Old Nov 13, 2011 | 12:37 PM
96 lt-4's Avatar
96 lt-4
All the more reason to have one ground for YOUR application.
Old Nov 13, 2011 | 12:56 PM
cv67's Avatar
cv67
St. Jude Donor '05
One of the best custom grind guys out there.
Google Chris Straub
He will get it "right" the first time
To Cam recommendations
