Need electrical help
Old May 6, 2002 | 08:15 PM
kattim1's Avatar
kattim1
Default Need electrical help
Dash lights have gone out. turn signal indicater lights stay on. Everything works except the lights,neither when the headlights are on or not. The only thing I have done is to bleed the brakes, took it out for a ride everything fine. Got in it to go to work,looking at no lights and the two lights for the turn indicaters stay on. Any guess would be appreciated. (feed back maybe? but from what?) :confused:
Old May 6, 2002 | 08:40 PM
JonM's Avatar
JonM
Default Re: Need electrical help (kattim1)
Try these sites
http://www.batee.com/corvette/
http://www.corvettemagazine.com/1999...ash/dashp1.asp
Old May 6, 2002 | 10:25 PM
jfb's Avatar
jfb
You have lost the ground for the cluster circuit boards and the ground current is flowing through the turn signal lamps to ground which keeps them lit. The board will have to come out and you will need to search for the open ground.
Old May 8, 2002 | 09:33 PM
kattim1's Avatar
kattim1
Default Re: Need electrical help (JonM)
thanks for your help any way to easily find the ground that is behind the left head?
To Need electrical help
