383 throttle follower issue
Old Nov 14, 2011 | 08:01 PM
sp361t's Avatar
sp361t
Default 383 throttle follower issue
looking for some fresh ideas. I recently built a 383 with 113 heads LPE 219 cam and the stock TPI intake. the car runs great expect for one thing.
If i am drive and push the clutch in to stop say from 35 MPH the idle will hunt untell i stop and then it will hunt for about 1 min then the idle will smooth out.
im sure its somewere in the tune but im not sure what direction i need to go any ideas?
thank you for your help.
Old Nov 15, 2011 | 12:41 AM
Cliff Harris's Avatar
Cliff Harris
What year? What version of the ECM firmware are you running? I assume it has been tuned, given that you've made fairly large modifications to the engine. Who did the tuning?
The throttle follower works by opening the IAC valve as you press down on the gas pedal. The purpose is to prevent the engine from stalling if you suddenly release the gas pedal and go to idle, which would cause the throttle blades to slam shut, cutting off the air. The throttle following mode has a "decay" value that gradually closes the IAC valve over time. I don't remember offhand if a large decay value means the IAC closes in big STEPS or a small decay value means there is a short TIME between decay steps.
My car is an '86 automatic, so the code is BUA. I don't know how the code handles a manual transmission, which is obviously quite different from an auto. I see some stuff related to DFCO and TPS Follower Gains that might be what you're looking for. Also there is mention of Stall Saver parameters that might be applicable.
I zoomed around in the code and it looks like it's a parameter called Trajectory Decay, which is in the TPS Follower Gains area. It's a TIME between steps.
I also found another parameter in the PID area that inhibits TF mode unless the TPS is over a certain percentage. I guess that could mess you up if it's too small.
Sorry I couldn't be more specific. Hopefully this will give you a better idea of where to look.
Old Nov 15, 2011 | 10:21 AM
WW7's Avatar
WW7
I recently had a problem with my throttle sticking, when I was cruising down the road and let off on the gas the car would keep going at the same speed without slowing down..I have a 383 also and when I was setting my car up for my tune, my Tuner (Mick Stevens) told me to set my IAC counts to 40..When I checked my IAC counts after the problem started I had them set at 10 counts. I don't know how they got to 10 but they did...As soon as I set my IAC counts back to 40 my car started decelerating like it should and ran normal again. I say check your IAC counts again and make sure they are where they should be , and also check to make sure your TPS is set to where it belongs...WW
To 383 throttle follower issue
