Removing Leather Shift Knob '89 Auto
Old Nov 15, 2011 | 01:26 AM
mako41's Avatar
mako41
Default Removing Leather Shift **** '89 Auto
Help me out..............
I'm trying to remove the shift **** from an '89 Auto.
I pried out the plastic shift button, removed the metal retainer, and removed the internal snap ring. The **** will move up a couple of mm but thats it. Is it screwed on? Do I need to turn it off the shaft, or should it pull right up?
I know someone has removed one from an auto, whats the deal?
Old Nov 15, 2011 | 04:15 AM
gerardvg's Avatar
gerardvg
It should pull of from the shifter rod, when shift **** button and the circlip securing the **** to the shift rod preventing its removal is removed. It may be difficult to remove if the recess for the circlip to position in is burred. I fitted a new shift **** a few months ago and had no problem.
Old Nov 15, 2011 | 06:52 AM
c4speed's Avatar
c4speed
From: Atco Raceway in between Pa & Nj 13.073 @ 106 MPH
You got to eat your Wheaties first.
Old Nov 15, 2011 | 09:01 AM
WW7's Avatar
WW7
Pull hard!!!!...It'll come off....WW
To Removing Leather Shift Knob '89 Auto
