Need to raise engine to drop pan?
Old Nov 20, 2011 | 01:35 AM
armybyrd's Avatar
armybyrd
Default Need to raise engine to drop pan?
Ive read on most cars in order to drop the oil pan you need to raise the engine off its mounts-is this true with early C4s?
Old Nov 20, 2011 | 02:37 AM
gerardvg's Avatar
gerardvg
You can remove the oil pan as it is.
No need to move the engine, you may need to remove the starter to get to a few bolts but that is about it. Go for it
Old Nov 20, 2011 | 03:48 AM
Joe C's Avatar
Joe C
- i've dropped the pan on my 85 without moving the engine. biggest problem - keeping track of the exact location of the bolts, studs, nuts, brackets, clips, etc - some 2 dozen pieces. make a mental note of this or you'll be saying "WTF" also, i recommend the felpro one-piece gasket - the only way to fly.
Old Nov 20, 2011 | 04:44 AM
armybyrd's Avatar
armybyrd
just looked on autozones website and theres a few gaskets. Is this the correct one for my '88?
Part Number: OS34500R
Old Nov 20, 2011 | 10:30 AM
Bullseye54's Avatar
Bullseye54
As said,pan comes off in normal position.May need to rotate the engine for crank clearance.I removed the hose to the oil cooler(5/8 tube running under pan).OS34500R is the perma dry felpro kit for the 88 according to Rock auto ,I've never had a problem with a one piece felpro.Lift the car as high as you can for working room.............Bob
Old Nov 20, 2011 | 11:01 AM
black88z51's Avatar
black88z51
No you don't need to raise the engine, although it's an alternative way of doing this. Everything the guys said above plus you'll need to remove both frame braces also. At least I had to my car's a stick I don't know if that matters. Don't forget to turn the crank if necessary or the pan never comes out. I made my own gasket from tube and no more leaks. Good luck.
Old Nov 20, 2011 | 11:19 AM
mtnmanut's Avatar
mtnmanut
i have an 84. drop the starter for three bolts and pull the pan. as far as a gasket,i used a can gasket once,(the right stuff) for a pan gasket. the stuff will seal up diareah on an elephant. but i about ruined the pan trying to remove it later,it took a hammer and chisel.
Old Nov 20, 2011 | 03:09 PM
Bullseye54's Avatar
Bullseye54
FWIW I didn't have to take the braces off,mines an 85.Try it with braces on & if it doesn't work take them off.
To Need to raise engine to drop pan?
