What's This Switch For ?
Old Nov 20, 2011 | 09:08 AM
C409's Avatar
C409
Default What's This Switch For ?
..... There is a micro switch on the rear of the '87 A4 shifter that is open 'til the shifter is put into 3rd , 2nd , or 1st gear ... this must be for ECM purposes ... maybe TCC ? ... I can't find anything descriptive about it in the Factory Service Manual ... I installed a B&M Megashifter in the car yesterday and can't find any way to mount and/or activate this switch ... I kinda hate to eliminate something when I am not real clear about what its for ... especially on computer controlled cars ..................
Old Nov 20, 2011 | 09:21 AM
RichS's Avatar
RichS
I think it's lockup enable switch so the converter will only lock with the shifter in 4th.
Old Nov 20, 2011 | 09:27 AM
Pete K's Avatar
Pete K
I always thought it was so you could not pop the rear hatch, unless you had the shifter in the park position.
Old Nov 20, 2011 | 10:51 AM
c4cruiser's Avatar
c4cruiser
The only thing in the FSM for a switch on the shifter assembly is called a "transmission position switch" Look in the Electrical Diagnosis manual on page 8A-201-8 in Figure A. It's not very clear where the switch is located on the shifter.
Your pic shows a switch that appears to be new given the dark color of the shifter; did you replace it?
Old Nov 20, 2011 | 11:14 AM
C409's Avatar
C409
..... The gear selection switch is the big one on the side of the shifter that activates / contains the neutral safety switch , back-up lights , and an ECM indicator to let the computer know whether the trans is in a drive gear or not ....
..... The switch is original ... the photographer is lousy ......
..... The switch in the pic is open until the shifter gets to 3rd gear or lower ... in other words no contact in P N R OD ...... that just seems odd ... which is why I asked , 'cause I don't want to screw anything up by disconnecting something important ............
Old Nov 20, 2011 | 08:24 PM
Mikky89's Avatar
Mikky89
This is shown clearly in my '89 FSM and is labeled "Overdrive Enable Switch". I agree with RichS.
Old Nov 20, 2011 | 08:45 PM
rodj's Avatar
rodj
But there is no electronic control of shifting on a T700 except for convertor lockup
Old Nov 21, 2011 | 04:00 AM
_twisted_'s Avatar
_twisted_
From my 86 Helms
Sections 6E3-C8-1 & 6E3-C8-2 Drivability and emissions
AT Overdrive switch
used by the ecm in OD to control clutch applies and releases, the trans doesn't have to be in OD to apply the clutch (TCC)
Figure C8-2 shows how to adjust it
More on how and when it comes into play shown in Chart C-8A
It's all about fuel economy and driveability - from what I read you can close the switch and TCC will occur @ 40mph or if you custom burned your chip what ever is set at.
So in a nut shell, jumping it out or manually closing the switch (closed in drive) may be just fine for you - by doing this TCC engagement will be delayed to that mph set point mentioned above.
For me I do this anyway by keeping it in Drive until I'm on a highway or interstate, because I hate lugging around in OD
Old Nov 21, 2011 | 09:09 AM
C409's Avatar
C409
Originally Posted by _twisted_
From my 86 Helms
AT Overdrive switch
..... ... Thats it ! ... I previously read the descriptive on C8-1 but didn't flip the page to see C8-2 ... until then things were rather vague about which switch was being referred to as there are some wires in the neutral safety switch harness that send info to the ECM ............. Thanks for clarifying ! ...........
To What's This Switch For ?
