Dana 44 needs setup in NY.
Old Nov 20, 2011 | 11:43 AM
RichardL's Avatar
RichardL
Default Dana 44 needs setup in NY.
Any one know of someone in upstate NY that has the tools to set up the ring and pinion gears of a Dana 44 properly? No one around here has the right tools. The dealer said they would do it, but would have to purchase the tools, and said the labor would be high.
Any one know of a good place in Rochester, Albany or even NY city to get this done correctly? The differential would be out, so I can drive, or send it to get serviced.
Richard
Old Nov 20, 2011 | 12:52 PM
cttech455's Avatar
cttech455
I had my ring and pinion changed out on my dana 44 last winter when I went with 3:75 gears. I went with a guy buzzy that builds the transmissions and sets up rear ends for quite a few short track guys in New england. Hes in springfield mass and charged me 150 bucks. I would try to get a hold of one of the circle track transmission guys near you if possible.
Old Nov 20, 2011 | 12:55 PM
qws's Avatar
qws
You can check with the fella that installed my D44,
Jims Garage in Ballston Spa
Old Nov 21, 2011 | 08:02 PM
RichardL's Avatar
RichardL
Any one else closer to NY state?
Old Nov 21, 2011 | 08:12 PM
qws's Avatar
qws
?? you did list Albany right? Ballston Spa is 10 min's from albany,NY
Old Nov 22, 2011 | 10:24 AM
HlhnEast's Avatar
HlhnEast
PM member Redrose, he is in the automotive trades and in upstate. He may know someone that can do it for you.
Old Nov 22, 2011 | 08:24 PM
RichardL's Avatar
RichardL
Done. Thanks.
Richard
Old Nov 22, 2011 | 08:26 PM
RichardL's Avatar
RichardL
OK, you got me there. Yes I did list Albany, but it is about a 2 hour drive to there. So Ballston Spa didn't sound familair at all.
So it is an option.
Richard
Old Nov 22, 2011 | 09:20 PM
WVZR-1's Avatar
WVZR-1
Richard
Richard,
I'd suggest you talk to a couple local performance shops in the area. There's usually someone or a couple of preferred builders that the locals use and recommend.
Your "SIG" seems to imply you do drag race from time to time, so I'd think you're well acquainted with most that could give references. The plus for you is that you can have it removed, you won't tie up someones shop.
I'd guess the area you're located in is 4-wheel drive country, nearly everyone of those builds are Dana's of some sort. I'm guessing in a "short conversation" with a recommended builder you could make a reasonable decision as to whether you'll get a quality build or not.
I was going to recommend Joe at Vette Tech in Newburgh but it's as much of a drive as Albany. Joe is I believe winding down his operation but you might email him joe@vettetech.com and maybe ask a referral.
I sold Joe a D44 NOS housing, batwing, differential, gears and short axles for his "Frankensport" project:
here's a couple links: http://www.youtube.com/watch?v=Q_hOVTNzM18
and here: http://www.vettetech.com/projects/c3gs/c3gs.htm
Old Nov 27, 2011 | 08:18 AM
RichardL's Avatar
RichardL
Originally Posted by WVZR-1
Richard,
I contacted Joe. He closed his shop 3 years ago. Great links though. Enjoyed them.
Richard
Old Nov 27, 2011 | 08:45 AM
STL94LT1's Avatar
STL94LT1
I had a 4x4 shop install my Dana 4.10's, and they are quieter than the original gearset.
To Dana 44 needs setup in NY.
