Help please????
Old Jan 5, 2012 | 08:11 AM
  #41
jls85vette's Avatar
jls85vette
Cruising
I will look and find that ecm number. It starts with 12. I remember that much of it, or I think so. Anyhow, I will get it and THANK YOU very much!
Old Jan 5, 2012 | 08:13 AM
  #42
jls85vette's Avatar
jls85vette
Cruising
A big and grateful THANKS TO ALL!!! If we had all of this help before. We would have had this baby running over a year ago. Thanks again to all for all of the help, tips and advice. We will try it 1 at a time and get this thing fired up again.
Old Jan 5, 2012 | 09:12 AM
  #43
oldalaskaman's Avatar
oldalaskaman
Originally Posted by Cliff Harris
Yep. Got me too. If the ground connection is open on the bottom TPS wire you'll get 5 volts going to the ECM instead of the correct .54 volts.
so...to get these readings you dont need to ground a-b on the connector...just turn the key on?
