[paging Vetts Red - JonM] timer location
Old May 7, 2002 | 11:45 AM
Fla96LT4's Avatar
Fla96LT4
Default [paging Vetts Red - JonM] timer location
I appreciate the help from you guys on the hatch and light problem. Do you know where the interior light timer is located behind dash? Is the best access through info center or breadbox or? I have replaced most of the dash plastic panels and am familar with how to dis-assemble trim pieces.
Old May 7, 2002 | 12:09 PM
dgoodhue's Avatar
dgoodhue
Default Re: [paging Vetts Red - JonM] timer location (Fla87)
It can be access under passenger side kick panel. If I remember right according to the service manual, it is supose to be taped to wiring harness, but I am not 100% sure (mine wasn't).
Old May 7, 2002 | 12:13 PM
JonM's Avatar
JonM
On my 84 the timer is located on the bundle of wires running behind the multiuse panel. It has electrical tape holding it to that bundle. It has a pink/white stripe wire-Pink/black striped wire- white wire- and a black wire running to it. It is a PITA...you may want to pick one up first before you dismantle everything.
Old May 7, 2002 | 05:46 PM
Fla96LT4's Avatar
Fla96LT4
Thanks for the reply..........time to go hunting! :rolleyes:
Old May 11, 2002 | 08:51 PM
Vette's Red's Avatar
Vette's Red
7th Gear
Hello I don't know if the message was sent . The book fell on the key board. Looking at the picture find the area of fuse block follow the wire bundle there are two brackets the wire bundle goes through right on top is the vatts decoder module with a nut securing the module Your little jem should be under it.
To [paging Vetts Red - JonM] timer location
