93 horn switch problem.
Old May 7, 2002 | 03:01 PM
93 ragtop's Avatar
93 ragtop
Default 93 horn switch problem.
Well my horn wont blow. The problem is the brass contacts that are between the steering wheel and the plastic buttons. I went to my local dealer and they ordered the buttons. These were the plastic part only. They think I have to buy a new steering wheel to get the brass parts. I find this hard to believe since they are seperate from the steering wheel. Oh and a new wheel is $782.00 Any suggestions on fixing this? Thanks.
Old May 7, 2002 | 03:38 PM
JonM's Avatar
JonM
Default Re: 93 horn switch problem. (Red 86 4+3)
Which part are you talking about? This is an older pic ignore the circles...I just noticed Your name is reference to 86 and your question is for a 93...Guess I can't help you.
[Modified by JonM, 2:55 PM 5/7/2002]
Old May 7, 2002 | 04:20 PM
rideklein's Avatar
rideklein
Hum... My left horn button works & the right one doesn't. Maybe the same problem???
Old May 7, 2002 | 05:42 PM
93 ragtop's Avatar
93 ragtop
Default Re: 93 horn switch problem. (JonM)
The horn buttons on the 93 are to the sides of the air bag. The brass or copper contacts, which are kinda springy, and they are not made onto the steering wheel. I knew I should have called 18 carfan but I was in a hurry since my inspection had died so I went to the local dealer.
To 93 horn switch problem.
