V6 drop in roller lifter?
Old Dec 1, 2011 | 07:02 PM
cv67's Avatar
cv67
St. Jude Donor '05
Default V6 drop in roller lifter?
Quite awhile ago the late CFI_EFI had posted up some info on a GM V6 hyd. roller lifter that could be used rather than a retrofit deal on a Gen 1 sbc.
Anyone have info/PNs on this?
Old Dec 1, 2011 | 08:32 PM
SunCr's Avatar
SunCr
Don't remember his post. Went to acdelco.com and looked up my old '95 Gran Prix and the Lifter is # HL118. That was on a 3.1 L and the x-reference shows that it was used on a boatload of stuff. It's still being used on 2011 Chevys (Impala sixes). You might call Scoggins Dickey - www.sdparts.com or Street and Performance - www.hotrodlane.cc
Old Dec 1, 2011 | 09:27 PM
BlackIce86's Avatar
BlackIce86
Here is what I have collected from other people's posts for evaluating my build.
"Here is information I collected from other sources. The information hasn't been check for accuracy but is a place to start.
17120070 (AC DELCO HL118)
SHORT Conversion - OEM for 4 cyl & V6
2.230" x .842" GM Hydraulic Roller
2.2L/134 OHV 4 1994-03, 3.1L/189 OHV V6 1993-03, 3.4L/207 OHV V6 1996-03
GM 17102014, 17120070
AC Delco: HL118
Dana-Clevite: 213-1756
Eaton, SBI: VL138
Elgin: HL2270
Enginetech: L2270
Federal Mogul-Sealed Power: HT2270
Hylift Johnson-Topline: A-2270
Melling: JB2270
Moresa: HR376
Stanadyne: T0082
VTI: RL280
Engine - Cylinder head & valves - Valve lifters
VALVE LIFTERS, S-Series - 2.2L 1994 - 2003
VALVE LIFTERS, All Models - 3.4L 1996
VALVE LIFTERS, All Models - 3.4L 1997 - 2003
VALVE LIFTERS, Beretta, Corsica - 2.2L 1994 - 1996
VALVE LIFTERS, All Models - 2.0L, 2.2L OHV 1994
VALVE LIFTERS, All Models, Eng/Code J - 3.1L 2000 - 2001
VALVE LIFTERS, 3.1L, 3.4L - 3.1L, 3.4L 1997 - 2003
VALVE LIFTERS, Impala, Monte Carlo - 3.4L 2000 - 2003
VALVE LIFTERS, 2.2L - 2.2L SOHC 1995 - 2002"
A member Dan, built a 400 using the V6 roller and said that a lobe lift of about .330" is the maximum with out unporting the oil. Again, this is all second hand info that I personally have not confirmed.
Old Dec 1, 2011 | 10:13 PM
JackDidley's Avatar
JackDidley
I found that info on thirdgen not ot long ago. I think it was all in one thread.
To V6 drop in roller lifter?
